Not to be a smart ass... but until it goes into protect.... Pretty quick if you try to crank it..
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
I guess I should have added, .25 ohms, wide open on music, and at 18.3 volts.....
And yes, eventually it went into protect from overheating, but it took about 10 minutes cranking on it pretty hard. As soon as it cooled down, it came right back on and started playing just fine again.
Props to Jacob for building a hell of an amp that will take some abuse. It's wired back up at 1 ohm now, and playing great. You guys know I have to stress test everything!!!!
You didn't say 18.3 v thats a little different there... but I should have guessed that coming from you. I would have guessed about 5 to 6 mins....
I do box designs.
The reason for my statement is I ran My Hifonics XXthor for over an hour on a TC sounds 5200 way over at volume 52 when my headunit is set for 40. This was on bass testers before smoke started to pour out of the box since I fried the sub and the ohm load was .35 and that was over an hour of constant abuse and the amp was just fine was barely even warm. That sub was only about a week old also
When I first wired up my 3000d and dual 1ohm DC Audio 15s I accidentally wired it to 0.25ohm cause I was so used to wiring my dual 2ohm Cvrs to 0.5ohm. I drove with it playing for 15min straight keeping the volume up but just low enough that my voltage stayed in the 12s. No problems at all and it never went into protect.
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
