I've heard that underpowering large subwoofers can burn it up due to air not being able to get to the coil..
How do you determine this? I'm asking because if someone has two 18D2s and they run two amps for competition, then one amp @ 2-ohms for daily, that would only be 1/4 of the power getting to the subs. Do you base it solely on excursion?
Example:
2 Fi BTL 18s D2 (since everybody seems to know them)
2 4000W amps for competition and just one for daily...
Could that potentially burn them up? I haven't seen any threads with this question.
Need an install? Hit me up.
[email protected]
your example doesnt underpower them so its moot
Heh, I figured that much, but I'm wondering when it becomes dangerous and how to know.
EDIT: With different applications of course.
Edited by Neo_frog
[email protected]
every time you turn the stereo down you under power the sub
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
it depends on the box
make it too large and you rip the cone and shit up
make it too small and the cone/vc/spider don't move enough thus making the vc overheat
you heard wrong.
Even if a sub moves a little it will still move air enough to cool, and besides, there isnt enough power to heat up the coil that much anyway.
too little power cannot blow a sub, its impossible. What too little power can do is cause you to turn it up too much and play into distortion.
Distortion is not good but also cannot alone blow a sub. Its the extra heat caused by the distortion.
The setup you listed will be fine though
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
oh and its near impossible to "blow up a motor"
exactly, just part of the motor. i.e. the coil
Ed Lester
ShowtimeSPL Host
My old Build Log
Ive seen it done a few times myself, but only in cases where there was an actual fire, and it heated the glue up that holds the magnets, and top plates together, and then a top plate shifts, and catches the coil
or on crappy subs where the motor is glues to the frame, not bolted, and the glue heats up, and the motor drops off and breaks
but thats about all I seen
