I have never used Titebond before, how hard is it to sand? I am actually using Titebond III, if that makes a difference.
Edit: Any tips on using this stuff?
Edited by banginAltima
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
its not to bad.
if you take a wet nap, and ipe the titebond from where its runnning you can end up with some pretty nice seams.
we use titebond at work ( titebond II _ and it comes off pretty easy with some rough sand paper.
EDIT for your edit: its your friend!!! use alot of it, if it aint running down the sides of the box you didnt use enough, because the glue is really what holds your box together in the long run.
Edited by dwright27
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
What about using it to fill a seem or hole?
I do box designs.
it'll work for that too bro. use a good bit, let it dry and then put a lil bit more on.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
if your talkin about the wood glue that stuff is really good it seals my boxes up really nice and make them have a better sound than before.i have used it on two boxes that were not built good (used boxes) and it made them sound a lot better just by putting a bead down every seam and lettign it dry
Hooters builds boxes now?
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
titebond did not make your box sound better. sealing it up did. lol
Titebond = the shit. We buy the red kind(original i think?) by the gallon. Just keep a couple of the little bottles around and refill them, works great.
As for sanding it, it sands very easy. I usually run the edges of my box with the belt sander at work, works great... or my angle die grinder with a 80grit pad will take it down quick too.
Kenwood eXcelon 995
  • Who's Online   0 Members, 0 Anonymous, 455 Guests (See full list)
