Port Advice, Just Got Metered Need Help
alright i just metered my grand cherokee the other day and i hit a 147 in the kick 34hz peak on tl outlaw ....first time ,,kinda sux, i really wanted 150.... i think my box is tuned a little low ....i am running 4 mtx 9500 12's in a 10cu ft after displacement box . the box has 2 slot ports 3.5 x 10 x12inch can someone tell me what its tuned at and how short should i make my ports to achieve higher spl.... im also getting some major flex issues which has got to be hurting my score
Edited by jimbo92259
4 mtx 9500 12's/ w 2 te1501d's fiberglassed
my cardomain
my myspace feel free to add me, just let me know your from SMD
34hz is super low to try to burp with but nice for music.. For SPL you will want to raise up the tuning to get a better score. You can do this by making the ports shorter. I would cut off an inch and test, another inch and test and so on until the numbers quite going up.
The best thing to do would build a box that is closer to the res freq of the truck. I would guess it's in the mid 40's in hz.
If the flex issues are with the box then u need some bracing. if it's with the truck, there is a few things you can do like foam, sound deadner etc. It may or may help your score. Stuff like that can also change the res freq of the truck also, so keep that in mind.
if it is 10 cu ft
3.5 x 10 x 12 long
about 33 hz if i did it correct
Tibs 99 F-150 Build 8 twelves
8 - Re SE 12"s
2 - SunDown Audio Saz-3000d's
1 - vx4004 planet audio amp
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
The flex will change some with the tuning. It won't be as dramatic I would shoot for 42-45hz. it's higher to help increase your score without losing too much low end for music.
If a meter is hard to come by then it's a matter of changing before each show2 and keeping track of what u do and how much it changes. I made 26 boxes one year competing. the only meter time I got was at a show.
Breaking a 50 is hard work, but worth it.
i dont know how many times ive heard that :) Dont put the meter on the dash or you will REALLY be dissapointed :D
147 doesnt suck though man (even in the kick) - its actually pounding pretty hard at that point.
Follow my Tweet (Twitter)
Those are respectable #'s at that low of a freq. I agree with Kingsuv....bring the tuning up and open up the port a bit if you're after #'s.
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
For 40hz you'll need to make each port 7". If you want to go higher just cut off a half inch until you stop gaining on the TL. Then you will have the highest peak that your car wants to play.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
