Thats cool, how hard were they to do up?
Edit: How is the imaging with them being down there, and also what kind of processing are you using?
imaging shouldnt be a problem, they are angled up a little...the mag on them is large so i was only able to angle them so much...also i didnt want to take up to much space and there perfect for what im needing...the tweeter's are hidden and i love that even more....they were not that hard, i got to use my new router so that was fun....hardest part was getting the amount of hardner down as i was doing them when it was 30 degrees out
its 2 custom built crossovers
4 6.5 selenium mids
2 neo tweets
crunch by maxxsonics pzi 900.4 bridged
pioneer 4000 now....
pioneer avic-n1 down the road
Edited by loganberry
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
Thanks for the reply, i thinking im going to have to steal your idea on speaker placement if i dont do a power window setup. Good luck with the rest of the build, seems like everytime i save up to fix mine up more, things start breaking. Just recently had to use system money on a rebuild transmission, then again on replacing my timing chain(starting that next week), then on top of everything else, im moving at the end of the month.
Again good luck with the rest of the build, and i'm looking for one of these :hairtrick: with that blow through.
:good:
formerly known as Blue86f150
this sux camel dicks
i hear you on problems...the engine was completely rebuilt and so was the tranny now i have a over heating problem and its one of 3 problems, simple head gasket, thermostat or one of the heads...im hoping something easy but havnt tore it down to look at it yet...not really looking forward to it...may have to tow it to autorama but ill be there
i love these body styles tho...and the diesel soudns great with the aftermarket turbo...its not super quick but goes plenty fast enough
My F-150 Build
wheres the build log on your pods? after seeing the sub boxes and how they came out, if these are so nice i would have thought youd have posted these for redemptions sake?
loganberry, What tweets did you use?
Ken, Where did you crossover at?
Wheres the pics of the pod build?
the best crossover frequency for the mid/tweets used I believe was 2600hz or 2750hz 12db ( I forget the exact cut off- but ended up great in testing )
to my old man ears they sounded a little treble high, and was going to use a common 12v auto dome lamps as a power difuser on the tweeter line, also acts as a resistor on the higher freq so they don't get to loud at un wanted freq's, and over powered
They do pick up in the higher freq and can be very bright.
Loganberry, Work with a little poly-foam if you want a little more midbass out of them.
the tweets are vifa
ill try some poly fill and see if i get any more response out of them
no pics of pod build....figured whats the point if it will just get picked apart and told how horable it looks (even when they look nice) and blah blah...im happy with them, and they sound great so at the end of the day thats all i care about
My F-150 Build
They are Vifa, not Morel
