roscoe1129 Posted February 4, 2009 Report Posted February 4, 2009 Taken from: http://www.tintcenter.com/ All window film deteriorates with age and eventually have to be removed. Two of the most common symptoms of dying film are the dreaded "purple film" and the "bubbling film". Purple film is caused by non-metallic dyes in the film breaking down and changing color. Bubbling film is a sign that the adhesive used to apply the tint to the window is failing. After a single bubble appears, many more will follow. So you are a true handy-man. These are the household items you will need when removing window tint: Black Trash Bags Ammonia (undiluted) Super-Fine Steel Wool Razor Blade or Sharp Knife Windex Glass Cleaner 3 hours of time Nice hot sunny day 1. Cut the garbage bag in roughly the shape of the window, spray soapy water on the outside, cover it with the black trash bag and smooth the plastic flat. Most window tint is constructed of multiple layers of film. When left under the hot sun, the garbage bag will absorb heat, helping the film peel off in one piece. 2. Protect all inside surfaces near the rear window with a tarp: speakers, rear light, and upholstered surfaces, then spray the entire window film with undiluted ammonia. Undiluted ammonia has a strong smell. It is recommended that you hold your breath or wear a face mask. 3. While the ammonia is still wet, trap the ammonia against the window film with another trash bag or plastic wrap. Park the car with the rear window facing the sun for an hour to soften the tint's adhesive. 4. Now we can start peeling the window film. Use your fingernail or razor blade lift the window film in a corner of the window, and try to peel the film off in one entire piece. Keep the tint moist with ammonia as you strip. Use a razor blade to scrape off any tint that did not peel. Be careful not to cut the defroster lines. 5. Remove the any residual adhesive with ammonia and Super-Fine steel wool, wiping with paper towel before it dries. Remove the exterior trash bag, and clean window thoroughly with glass cleaner. Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
Diablo Audio Technologies Posted February 4, 2009 Report Posted February 4, 2009 Hey this works, this is how I did my jetta window's, simplegreen 90/10 solution works well to, the sun is the key it heats up makes it easier.
Gotloud555 Posted August 11, 2009 Report Posted August 11, 2009 INteresting.. It take 3 hour to remove just that backtnt... WOW!!
TahoeDD Posted March 4, 2010 Report Posted March 4, 2010 I removed 2 side windows with all residue gone in about 45 minutes. Just need a razor blade, a very steady hand, and let your windows bake in the sun and it will peel off with any soapy solution. I will note it definitely wasn't easy.
n8ball2013 Posted March 4, 2010 Report Posted March 4, 2010 remember to vent car when working with ammonia. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
wolfpack Posted March 29, 2012 Report Posted March 29, 2012 what also works is using a fabric steamer, takes the glue off too. 2010 Subaru Impreza Pioneer AVH-P1400DVD 2 10" Rockford Fosgate Punch HX2 Audison LRx 1.1K superglue a dildo to the center of the cone....lube it.....then have that dumbass sit on it while playing a 10hz note haha, this reminds me of a paintball sticker i have "my balls slap at 300fps" now I want a sticker that says "i fuck at 10hz"
1996BLKBauer Posted May 23, 2012 Report Posted May 23, 2012 My father is a profession Window Tinter. He only uses Ammonia to remove tint. It works great, just make sure you have good ventilation, I tint windows as well, and trust me you need good ventilation. What we do is peel as much as we can of the old tint off, then we spray the Ammonia on, let it sit for a while. We then use a razor blade to scrap the rest off. Also, just in case nobody knows there is Ammonia in Windex, it will over time with cleaning destroy the tint. I just use Vinegar and water. 1996 Ford Explorer Eddie Bauer V8 AWD So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
Robert8252 Posted May 23, 2012 Report Posted May 23, 2012 Stoners has a great aerosol window cleaner tha is safe for tint. Also anyone trying this on your back window, take your sweet ass time because fixing defroster lines is a pain in the but. 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
Kidd_Bass Posted May 23, 2012 Report Posted May 23, 2012 I made money removing tint before real easy to do
correysmith321 Posted June 5, 2015 Report Posted June 5, 2015 The same tools and equipments used for the car window tinting project that is being done in the pictures are the same things that I use. For me, the difficult thing of doing a car window tinting was trying to have the film stick to the window. It seemed like every time I applied a little bit of water and later spread it around using a scraper the film would come off. What would be the best and easiest way to have a tinting film stick? http://www.tintcenter.com.au/services
