Torres' Box Tuning Calculator - Updated 8/18
Torres
on torres i made a box for 4 12`s for woofer displacment i add up all 4 correct? for example my displacment is .7. im using 4 subs so do i put in 2.8 under woofer displacment
Yep
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Hope is just an example as I can't think of many 12 subs that will be over 0.2 cf.
  • 1 month later...
  • 3 weeks later...
Still like using Torres, just wanted to say thanks.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
can torres be set to do a side port sub front so i can do a long straght port without having to bend it?
You will have to switch around the dimensions to make it work. But if you are running more than one baffle it wont
  • Who's Online   1 Member, 0 Anonymous, 944 Guests (See full list)
