Torres' Box Tuning Calculator - Updated 8/18
Torres
Here is a strange bug. Sometimes port aera/per ft wigs out and gets a bad value in it. In the next two screenshots you will see two identical boxes with different values in the port area/ft box.
All i had to do to make it change was a value in some other field and then change it back.
It only seems to get this error when adjusting port width. I don't think it matters how many common walls but i see it more often with 1 common wall designs.
bug1.jpg?t=1352734548
bug2.jpg?t=1352734549
edit
added a few extra letter "s".
fail keyboard is fail
edit: Does it with other common wall settings too. It seems like it pics a random number to put in that field. I was using a 3 common wall with a port height of 16.5 and kept changing the width of the port like 1 ,2,3 ,4 and the values i get are 0.00, 0.00, 7.88, 12.4, If you just replace the width with the same width it gives different numbers also.
for instance, width at 4 i get 12.44, if i replace 4 with 4 again i get 16.58.
People should probably take note of this. Can someone else try this and see if they get the same results. I am using the most current version, i even downloaded again after i had this happen to make sure. I think if you enter the same port width twice it gives the right number.
is the newer version of the calculator more accurate? i get two completely different measure using the same dimensions between the two versions.
old
new
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
i downloaded the toress calculator but it says i need framework v4.0.30319 to run it or something. i need some help. i do not know how to use computers
bam
]http://www.microsoft.com/net
ok so im sure this has already been answered but i dont want to search through 24 pages to find it. If my sub is firing upward but i dont have a baffle, do i need to just add .75 to the height?
Kenwood Excelon x396AQ2200Fi Q 12XS D3400
XS XP30001/0 RADAFLEXStinger volt meter
Mechman 240a alt
you cant.
mac ftw lol
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
