My Son Just Made My Night...
When my son was 6, I was building a set of line arrays in the garage. three of the drivers came in with crushed dust caps. Blake insisted on building his own speaker from scrap wood with those three speakers. . .
Posted Image
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
haha i love it! good luck wit the build bro
it makes me happy to see such enthusiasm for this hobby
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
I didn't have the heart to tell him those little eight's will not give him the same results that are in Steve's video's
That doesn't even matter man, just do the build and get everything done and I guarantee you when you first crank up the volume and he sees and hears those little 8"s bumping it'll make him giddy as ever and he'll be ready to go bigger and better. Getting the kid hooked early!
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
hi there lil man i so glad your here, and also do your chores and homework before play, just build your box the way your mind tells you to, i see you have it all figured out with the box calculator, i wana see the pic tures of your build, what amp are you hooking up. keep this up.
This is Andrew the little guy.......Thanks for the idea to put the ports in the middle....
Were starting are build list tonight, and will be getting are supplies for the weekend.
Thank you for the enkeregment for the build.
Good stuff Andrew! just one question your ports say 2x6 is that 2l x 6w or 2w x 6l?
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
Good luck kid! DO WORK!
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
He has chosen to do two 2w x 6l ports. Little mans in bed right now so i figured I would answer this for now.. Ill have him check the board after school tomorrow and see if there is anything else he wants to add.
Also if my calculations are correct it should be tuned to about 42-44...If someone wants to recheck that I would be greatly appreciated also.
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
As the little man stated we started the build log and material list. I sat there and asked what we needed and he started to rattle of things some good ideas and some kinda out there, but here is what we ended up with. Wood, screws, wood glue (impressed he thought of this one), the PVC, paint and nails but we took that off. Now he got all the stuff on the list on his own except and then i explained that there was two more things we should pick up caulking and wood filler.
So now we are at Lowe's and staring at the sheets of Fiber Board and he says..."Dad how are we going to get this home, its not going to fit in the van" I told him since we will be making a smaller box we can have them cut the sheet in half and it will fit.. he was like cool.
Got the wood cut and started to make our way through the list. 2" PVC, wood filler, wood glue and then we hit a road block.......Yes the paint section.....He looked so confused with all the paint sitting in front of him and not having any clue what one he wanted.. It was comical to say the least.... So we narrowed if down to 4 different textured type of paints. Black, brown, redish and a gold. I sat there and thought to my self "not the gold....not the gold...) :D... then he picked up the black one and said this is it dad. Then we grabbed the screws and headed to the check out.
The whole time he was saying cant we just start working on this tonight. Or even Friday, it not that cold out side....Man I might just give in and let him start after school tomorrow. We'll see how his day goes. But we snapped some pics when we got back home from Lowes..
Had to stop off and get some food for the machines before we unloaded... :clapping:
Posted Image
Helping getting the wood out of the van so that we didn't scratch up the bosses (wife's) Van
Posted Image
Grabbing the goodies out the back....
Posted Image
This one kind looks like he just stole something... :ph34r:
Posted Image
So he gave it a world class effort to help carry the wood in....
Posted Image
But it was just a little to big to get his arms around, so I gave him a hand....What a dad.. :clapping:
Posted Image
So it was a very productive night. Till tomorrow..
AWESOME! Only concern is the 2" port is gonna cause some noise but its not like you cant refigure later and put a wider one in as long as there is room.
Andrew, I know your excited as hell but dont rush it take your time! I will be gone for a bout week starting friday but may be able to look in if not i expect plenty of pics and a vid or two when I get back!!! Good luck! :)
Scientia est Vox
