i am really trying hard to come up with the money to get some new amps and i was thinking about 2 saz-2000, but what about the saz3500? i can get two 2000's for the same price as one 3500. im guessing i would come out ahead getting the two amps. what do you guys think? right now im running two 15's but before the year is out i want to go with 2 or 4 18's
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
id say go with the 2000's cause you will comeout ahead if you need to get 2 more also. and one per woofer. but then again you can keep your mass of equipment down with the 3500. i see you have a suburban though. so i take it space doesnt matter in that beast.
And far as the best connection ever.......
get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together.
2 2000's will put out more power than a single 3500 and it will allow you to run one amp per speaker resulting in less impedence rise thus making more power. They will draw more current than the 3500 so you may need a little bit better electrical setup, but if you are spending the same amount for 2 amps as you would for 1 then it's a no brainer.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
thats what i was thinking. i just hope i can come up with enough for two. thanks guys
d(-__-)b
Well put...
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
