Determine the F3 Factor of your woofers, then use that to decide whether or not they would work well in a sealed enclosure.
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
Good subs for a sealed enclosure have a floppy suspension, expressed as a low Q and high Vas in the TS parameters. Could you post a link to the spec sheet?
Drivers good for a ported box have a higher Q and lower Vas.
Im pretty sure that subs made for sealed enclouseres have higher Q values and ones for ported have a lower Q value. Atleast that is when talking about Qts values.
just did a 15'' AA Avalanche in a kids truck...Those Ava's like them some sealed boxes :)
J.A.M AUDIO
Owner
North Texas
Authorized DC Sound Lab Dealers
This is correct. Low EBP and high Q are generally good for sealed. There are other parameters that will cancel this rule though in some cases.
Need an install? Hit me up.
[email protected]
Sorry for the thread jack but,
Which parameters? I knew that there were other parameters that determined weather a sub with a high Qts value would peform well in a ported enclouser but never found out which ones. Ive been searching for that with no luck. Also is that the same for putting a sub with low Q's in a sealed box?
4 CVR 12's, 5.5ft^3 net Sealed box- 1400rms total 1997 cpe best burp was 146.3Db in the kick TL mic.
Had 4 CVR 15's inj 8.8ft^3net Sealed Box off the same power/same car and it was about +2db.
4 Phoenix Gold Ti 12's in 4.5 ft^3 net Sealed Box off same power/same car doing same as the CVR 12's but could be louder with more power.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Since "Loud" is a relative term....you should prolly mention what those setups did on mic or that post is kinda worthless.
*Also* I did NOT mean to say My setups were in fact "LOUD"...at least not by SMD standards since ist's kinda 150+club round here all day, but I was guessing the OP was looking for "what can I expect out of a given sealed setup in a given car"...Otherwise he was just bored and done J/O to Pron.
On this, what qualifies as "high" and "low"?
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
  • Who's Online   0 Members, 1 Anonymous, 3170 Guests (See full list)
