Best Amp For Under $200?
k3n12ock
NO NO NO peeps. this be the best ;)
http://www.audiosavings.com/products/US-AM...b31.r3a8bd.aspx
free shipping aswell :D
ew no
2nd one will be more efficient than first
ohm load is dependent on sub wiring.
how many subs? one? two? four?
Will that us amps put out rated power? It said 1 krms and had 90 amps fusing
Eclipse cd7000
I also have no idea on how to wire to 2ohm, ohm, 1 ohm, etc as I can only run wires and am a noob at everything else.
check the rockford fosgate woofer wiringwizard
2 8ohm dvc subs can be wired to 2 ohms or 32 ohms
2 4ohm dvc subs can be wired to 1 ohm or 16 ohms
2 2ohm dvc subs can be wired to .5 ohms or 8 ohms
2 1 ohm dvc subs can be wired to .25 ohms or 4 ohms
2 8 ohm svc subs can be wired to 16 ohms or 4 ohms
2 4 ohm svc subs can be wired to 2 ohms or 8 ohms
2 2 ohm svc subs can be wired to 1 ohm or 4 ohms
2 1 ohm svc subs can be wired to .5 ohms or 2 ohms
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
yes, it will @ 15 volts. a lil over rated.
EDIT the one we tested did.
double EDIT: us amps has gone down in quality.
try to find a lanzar opti amp. those are really good, or so ive heard.
i heard they use soundstream guts
I have 2.
Some info on those subs:
Evolution Series 12" High Performance Subwoofer
Dual 4 Ohm Impedance.
Non-Pressed Kevlar Composite Spruce Pulp Paper Cone.
Dual Black Conex High Excursion Spiders with High Current Woven Tinsel Leads.
Aluminum Die Cast Competition Basket with Perimeter Voice Coil Aerovents.
Dual 4 Layer Vented High Temperature Black Anodized Aluminum Voice Coils.
Precision CNC Machined Front and Back Plates.
High Profile UV Treated Rubber Surround.
Customized Butyl Rubber Sealant Gasket and Magnet Boot.
Chrome Competition Spring Load Speaker Terminals.
One Piece High Polished Backplate/ Extended Pole Piece (Bumped and Vented).
Injection Molded Mineral Filled Convex Dustcap.
High Temperature Thermal Conducting Aerospace Epoxy Used Throughout.
RMS Power Handling : 450 Watts
Peak Power Handling : 900 Watts
Frequency Response : 20Hz - 500Hz
Sensitivity : 89.9dB @ 1W/1M
Mounting Depth : 5.75" (133mm)
Cut-Out Diameter : 11.37" (289mm)
PARAMETERS
Fs : 29Hz
Qms : 6.1
Vas : (Liters) 76.4
Qms : 6.1
Qes : .43
Qts : .40
Nominal Imp (Ohms) : 4 ohms + 4 ohms
SPL 1w/1m (dB) : 89.9
SPL (2.83V/1m) : 95.1
X-Max (mm) one way : 9
Pe - RMS : 450 Watts
Pe - Maximum : 900 Watts
RECOMENDED SEALED ENCLOSURE
Optimum Sealed Volume Standard Metric
Gross Vb Internal : .82 cu. ft 23.2 liters
F3 (-3dB cutoff) : 44 Hz 44 Hz
Poly-Fill : 12 oz. 340 grams
Qtc : .70 .70
Pe (Rms) : 350-400 Watts 350-400 Watts
Posted Image
Posted Image
Oh yeah, I like this Audiopipe
http://cgi.ebay.com/NEW-AUDIOPIPE-1800W-MO...93%3A1|294%3A50
