EricM9104 Posted May 30, 2009 Report Share Posted May 30, 2009 will it help by adjusting the phase control on the amp... or is it a design flaw with the enclosure? no it'd be the way your subs are wired. Quote 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
AI James Posted May 30, 2009 Report Share Posted May 30, 2009 may be wiring may be amp thing may be box Quote Link to comment Share on other sites More sharing options...
Mostar Posted May 30, 2009 Author Report Share Posted May 30, 2009 will it damage anything in the mean time while i trouble shoot the problem? It only does it when it hits real real lows on music, but i can play a 20htz tone and the excursion of both subs are the same. Quote '05 GMC Envoy H/U: PIONEER AVH P4300DVD Subs: ( SA-12's Amps: (2) SAZ3500d's MECHMAN 270A Alt and 5 Batteries with lots of 1/0 Link to comment Share on other sites More sharing options...
spl4life Posted May 30, 2009 Report Share Posted May 30, 2009 i agree with EricM9104... double check your wiring... on the subs... i had the same problem with a 2 10in setup... Quote My first truck... My first Real build... *Update 8/9/10 DC Power 270xp Alt is In!!!* 1997 Toyota T-100 DC Level 5 18" in a T-line Everybody wants their system to be.... 1. Cheap 2. Reliable 3. Loud ...you can only pick two. micahmye hertz pack Link to comment Share on other sites More sharing options...
spl4life Posted May 30, 2009 Report Share Posted May 30, 2009 i dont think it will do much damage as long as your not pushing it all way... Quote My first truck... My first Real build... *Update 8/9/10 DC Power 270xp Alt is In!!!* 1997 Toyota T-100 DC Level 5 18" in a T-line Everybody wants their system to be.... 1. Cheap 2. Reliable 3. Loud ...you can only pick two. micahmye hertz pack Link to comment Share on other sites More sharing options...
Mostar Posted May 30, 2009 Author Report Share Posted May 30, 2009 i agree with EricM9104... double check your wiring... on the subs... i had the same problem with a 2 10in setup... did you resolve the problem with your set up? Quote '05 GMC Envoy H/U: PIONEER AVH P4300DVD Subs: ( SA-12's Amps: (2) SAZ3500d's MECHMAN 270A Alt and 5 Batteries with lots of 1/0 Link to comment Share on other sites More sharing options...
tibs Posted May 30, 2009 Report Share Posted May 30, 2009 take the subs out and check the wires inside. Quote Tibs 99 F-150 Build 8 twelves 8 - Re SE 12"s 2 - SunDown Audio Saz-3000d's 1 - vx4004 planet audio amp big 3 1/0 gauge MECHMAN 250 amp alt MySpace Link to comment Share on other sites More sharing options...
Forevrbumpn Posted May 30, 2009 Report Share Posted May 30, 2009 Ive seen that before a lot, especially with the Powered4Sound Snail shells, John even said the woofers move at different rates due to the box design. Usually if the woofers both have equal excursion, but are moving at different rates, there is SOME phase issues, but not enough to be to concerned of, unless it has almost no out put but 1 woofer moving a lot, the other barely moving? odd Quote I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy. Link to comment Share on other sites More sharing options...
Mostar Posted May 30, 2009 Author Report Share Posted May 30, 2009 Here is a pic of the box design if it helps any....... Quote '05 GMC Envoy H/U: PIONEER AVH P4300DVD Subs: ( SA-12's Amps: (2) SAZ3500d's MECHMAN 270A Alt and 5 Batteries with lots of 1/0 Link to comment Share on other sites More sharing options...
tibs Posted May 30, 2009 Report Share Posted May 30, 2009 just double check your wiring. Quote Tibs 99 F-150 Build 8 twelves 8 - Re SE 12"s 2 - SunDown Audio Saz-3000d's 1 - vx4004 planet audio amp big 3 1/0 gauge MECHMAN 250 amp alt MySpace Link to comment Share on other sites More sharing options...
