will it help by adjusting the phase control on the amp... or is it a design flaw with the enclosure?
no it'd be the way your subs are wired.
will it damage anything in the mean time while i trouble shoot the problem? It only does it when it hits real real lows on music, but i can play a 20htz tone and the excursion of both subs are the same.
'05 GMC Envoy
H/U: PIONEER AVH P4300DVD
Subs: (8) SA-12's
Amps: (2) SAZ3500d's
MECHMAN 270A Alt and 5 Batteries with lots of 1/0
i agree with EricM9104... double check your wiring... on the subs... i had the same problem with a 2 10in setup...
did you resolve the problem with your set up?
'05 GMC Envoy
Subs: (8) SA-12's
Ive seen that before a lot, especially with the Powered4Sound Snail shells, John even said the woofers move at different rates due to the box design.
Usually if the woofers both have equal excursion, but are moving at different rates, there is SOME phase issues, but not enough to be to concerned of, unless it has almost no out put
but 1 woofer moving a lot, the other barely moving? odd
Here is a pic of the box design if it helps any.......
'05 GMC Envoy
Subs: (8) SA-12's
  • Who's Online   0 Members, 0 Anonymous, 1012 Guests (See full list)
