sri3850341 Posted June 1, 2009 Report Posted June 1, 2009 i vote faulty wiring...alllthough a budget oriented amp they are still pretty solid if you dont abuse them.. 07 mote carlo.. deh-p800prs hu-cdt gold 6.5's-cdt 6x9 2 ways-mcintosh mc431m(mids/highs) bxi2608,2 10w7's in 4rth order(designed by pete k)ported into cabin via armrest cutout dc power 260 amp alt-missing link module (15.4v)kicker 1/0 kit deka intimidator under hood metered 141.0 @ 32hz windows down @ kick,termlab
jmitch Posted June 1, 2009 Report Posted June 1, 2009 i have to say faulty wiring sumwhere in the set up but just take it sumwhere and let them look at it and they possibly tell what went wrong. I know a lil about everything so dont call me Mr. Know it All.
lanman31337 Posted June 1, 2009 Report Posted June 1, 2009 I bet if you crack it open most of your fets are gone. I've had a few hifonics brutus amps do that to me. 2 - Audiopipe AP30001Ds 1 - Lanzar Opti Scion 600.4 4 - Lanzar Optidrive 1232D's 1 - Lanzar Opti 5.1 1 - Lanzar Opti 6.1 1 - Lanzar Opti 6C midbass 1 - Alphasonic PCT6551 1 - Lanzar VX830 1 - JBL 22 band EQ 1 - Lanzar SDBT75NU 1 - AudioControl Epic160
alvitae Posted June 1, 2009 Report Posted June 1, 2009 ^^^ so since u ran tons of amps retartedly they should all be able to take it? I had a 1958 mote carlo and rammed it into a wall and it still ran, think i should do the same with my cobalt? are you sure u wired the sub correctly? i could be wrong but i just did all the coil configurations for a single sub in both dual and quad 4,2,1 and not one could be wired at 2 and 1(1.4/.7) so if it was actually at 1.4 before it was either... dual 4 so the only other rewire would be 8, dual 1(.7) able to be .5(.35), quad 2 able to be .5(.35) and 8 Actually what i said was I haven't had many amps, Not that I had tons. And actually I do think a 1 ohm stable amp should play at .7 ohms if it isn't flea market quality. I don't think that is why his amp blew up.
tequila Posted June 1, 2009 Report Posted June 1, 2009 how could box rise make it over 1ohms when the sub wasnt even playing in the first place? im just wondering. imo the amp blew cause of going below 1ohms. '99 Civic hatch 18" AA Chaos - 7cuft @ 34hz - 114sq in. port Mac Audio Fearless ~ 1000wrms @ 2 Ohms Videos: Youtube
Basshead08 Posted June 1, 2009 Report Posted June 1, 2009 noob+crappy equipment= poof! System tear out has begun...Out with the old i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell Look at the underlined text hahahahahahahaha I think of it as the virgin losing the virginity technique not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
wL<3bass Posted June 1, 2009 Report Posted June 1, 2009 imo the amp blew cause of going below 1ohms.You do relize that when you wire a sub to 1ohm its actaully .7ohm right.....he didn't go below 1ohm.....1ohm coils = .7 2ohm coils = 1.4 Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
emperorjj1 Posted June 1, 2009 Report Posted June 1, 2009 Actually what i said was I haven't had many amps, Not that I had tons. And actually I do think a 1 ohm stable amp should play at .7 ohms if it isn't flea market quality. I don't think that is why his amp blew up. i agree with you on that part a 1 ohm amp should be able to play 1 ohms nominal (.7ohm is 1ohm nominal as is 1.4 2 ohms nominal) but not half an ohm. i still have yet to see a wiring configuration for a single sub that can be both 2 and 1 ohms J. JMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
Boon Posted June 2, 2009 Report Posted June 2, 2009 I have an awfully sneaky feeling that the sub is a Dual 1 and he had it wired down to 0.5 ohms... if you measure a 0.5 ohm load with a multimeter you'll often get around 0.7 ohms read because of the resistance of your test leads combined with inaccuracy of most multimeters when reading that low. My Fluke reads a 0.5 ohm load as 0.7 ohms, I know my test leads have 0.2 ohms of resistance 10.x volts fo' life!
bennett15 Posted June 2, 2009 Author Report Posted June 2, 2009 sub is D2 when i put the leads of the dmm in the sub its reads 2.0 on each then if i wire it up to 2 ohm and put the dmm leads on the sub it reads 1.8? then when i put the leads of the dmm on the wires going to the amp i get a 1.4 reading. if i do the same but to 1 ohm then check wire going to amp with dmm it reads .7? sub is still sitting at 2.0 at each coil so its fine. 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
