  • 4 weeks later...
you should ground your amps within about 12 inches of the amps.
runs of negative cable from front to back are only useful if you have a battery in the back.
Nice to see another vw and another build.
Pushing it to the limits. Want more power.
might be the booze talking but that makes no sense at all
R.I.P!
(Nov-29-2009)
92 explorer
current build
I was gonna say the same thing. A lot of cars have a split body where the ground up front won't be the same ground as the one in the back of the car for the amp. It's ALWAYS a good idea to run a ground from the front battery to the back and use a ground block to split it off to the amp and the rear chasis of the car or to the rear battery.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
nice build, kinda sucks that they dont carry mdf, but that stuff should work, and that's a lot of screws in the box
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
how do you take off your rear door panels
you take apart the handle, remove plastic, and you will find two screws, after your scrow them, with a little forse you take the panel from the doors.
? makes no sense, only metter is that the all ground is in one spoot...
nice build for someone in Croatia...i was there after July 4th...beautiful place...
thx.
i would use mdf, but the store where the mdf is sold is very far from my town...
the reason i used so much screws is: material is wery weak at the joining points so the screws hold the week points.
