wow, that tuning is low. I would tune it higher if you wanna burp louder.
really its 5hz lower than the cabin resonance that you wanna tune to, but your cabin resonance should be higher because its a truck.
The reading over a 3hz range really is for consistancy, you really cant tune a box or play anything different to help it. Some cars have sympathetic vibrations that add harmonics in that range, but mostly the sympathetic vibrations cancel the wave rather than reinforce it.
If you wanna increase your score, I suggest a higher tuning.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
My port volume is not optimum(to small), at 36HZ. How much do you think this will hurt me, if it will at all.. EDIT, This should also give me more box rise?
Edited by CR Boom
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
Do you guys change your square" of port ,, to the Freq that you are tuned at?
Example my box 9.0 tuned at 31htz Should be around 149" of port, then at 36 it should be at 196" of port.
This is from carstereo .com port calculator.
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
from my understanding, your Sq inch of port is more guided with how big your box is, 9 Cubic feet at 15 sq inch of port per cubic foot is about 135. if your just doing 15.
just change the length of your port, if you make them smaller should raise the tuning
if im wrong please some one correct me, im still learning on ports :)
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
ideally you want 16 square inches of port per cubic ft if you are playing music daily or burping with moderate power however if it is a burp box with 1000s of watts then the rules change.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
Are you using round or square ports for your box? If you are using round ports you can get away with much less port area than you would with a square port. The round ports cut down on turbulence quite a bit and can help raise efficiency. With a slot port I'd say that your about right on with as much port area as you mentioned in a 9 cube box. If your doing round or flared ports then I'd say that you have too much port area and should knock it down to around 100 sqin.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
It is a slot port....
So no changing port size when I tune up, I recalculated everything last night, I'am at 31.xxx and want to change to 36, which is shortening my port to 8.xxx""" instead of 17"""..
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
Yeah don't change the port area, just shorten up the port like you already said. What is the exact measurement of your port right now? If you have around 149sqin of port it might be a little too big but only by about 10-20sqin total. If I knew your exact port I could tell you how long you need to make it to tune it to 36hz.
1 XS Power D3100
Audio Control LC6i
Stock Deck
  • Who's Online   0 Members, 0 Anonymous, 1887 Guests (See full list)
