bumonskateboard6 Posted July 7, 2009 Report Posted July 7, 2009 In my car at full tilt I sometimes have bad voltage drop down to the low 11's and as driving home tonight it seemed not as loud as normal so when I got home I opened the trunk to look at my subs and it seems like one sub is moving twice as much as the other one. Does anyone think that the drop in voltage could have damaged one of the subs because the amp is completely fine not hot, no protect, no fuses popped... Quote Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
EricM9104 Posted July 7, 2009 Report Posted July 7, 2009 When your voltage drops that much, you're gonna be clipping the shit out of everything. So yes, you more than likely damaged the sub. Quote 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
HHR Ed Posted July 7, 2009 Report Posted July 7, 2009 check wiring to the sub. Voltage drop will have nothing to do with the sub itself, but if it dropped below 11, you are in risk of blowing your amp. Quote Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
bumonskateboard6 Posted July 7, 2009 Author Report Posted July 7, 2009 check wiring to the sub.Voltage drop will have nothing to do with the sub itself, but if it dropped below 11, you are in risk of blowing your amp. I pulled the sub out of the box and it's still wired right and all the terminals are wired and in place too. It seems just like one of the coils on the sub isn't working... I know I need a new alternator too but the amp has been doing fine with no damage. Quote Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
chevyman217 Posted July 8, 2009 Report Posted July 8, 2009 I pulled the sub out of the box and it's still wired right and all the terminals are wired and in place too. It seems just like one of the coils on the sub isn't working... I know I need a new alternator too but the amp has been doing fine with no damage. WHat kind of subs do yo have???? And what kind of amp??? Quote Some people could care less about who the genius is that is making the product... They just want to get it cheap and say "derrrr, look at teh pretty lights in muh dash!" Because audio is a lifestyle not a hobby. Things that I am allergic too.... Haters Bitch Notes
Kian Posted July 8, 2009 Report Posted July 8, 2009 take the sub out again and stick a dmm in the terminals and see what each coil is reading more then likly your gonna see one coil's numbers all wacky. Quote --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped
bumonskateboard6 Posted July 8, 2009 Author Report Posted July 8, 2009 take the sub out again and stick a dmm in the terminals and see what each coil is reading more then likly your gonna see one coil's numbers all wacky. Yeah I have it disconnected right now so it doesn't cause more damage to anything and conveniently last week my DMM broke so the replacement for that's on the way too. Quote Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
Gotloud555 Posted July 10, 2009 Report Posted July 10, 2009 WHat kind of subs do yo have????And what kind of amp??? x2 and what kind of electrical upgrades? Quote
ALPINE408 Posted July 10, 2009 Report Posted July 10, 2009 do you have a 9 volt... 12volt or 18volt drill batt???? if you do run a wire to the pos and then anouther one to the neg of one coil then tap the prongs on the drill batt the sub should pop out or suck in depending on polarity (sp) then do the the other coil (if there dual coils) if one side dont do anything you got a bad coil Quote Have you ever had your woofers blown?
Bills Posted July 10, 2009 Report Posted July 10, 2009 do you have a 9 volt... 12volt or 18volt drill batt???? if you do run a wire to the pos and then anouther one to the neg of one coil then tap the prongs on the drill batt the sub should pop out or suck in depending on polarity (sp) then do the the other coil (if there dual coils) if one side dont do anything you got a bad coil Kurt thinks that kinda cool^^^^^^^^^!!! Bills Quote KwB Team DC Audio Midwest captain
