Running Power Wire Under The Car
for strapping wire to the bottom of your car i use Hurricane straps that are used on houses to brace rafters and roofs together. they come in a roll at depot and work awesome.
thanks for the help guys.
yo meade, do u cover the wires with anything? or u just leavce them as it is?
cheers
Shok Industries
Feel the POWAAAAAAAAAAAAAAAAAAAAAA!!
Competition SQ Car install by Dimension Audio Singapore
http://www.stevemeadedesigns.com/board/ind...showtopic=65190
theres also some little stick on plastic tabs with two loops for a ziptie to go thru. i found them at osh. if you clean up the surface real nice they stick amazingly.
And you could use some wire loom, but it's really unnecessary once you've gotten it under the car. I only use wire loom in the engine bay. And even then I sometimes don't, depends on how I have to route it.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
ooo ok man
thanks for the info
cheers
Shok Industries
I don't see any problem with routing your wires under your car....as long as it's done properly and FUSED at both ends.
Why both ends...?
If it shorts anywhere along the wire the fuse will blow. There's no need for 2 fuses.
Actually....yes two fuses are in order. Remember that you ALSO have batteries in the back and that a fuse must not be too far away from a battery (within 18 inches).
So let's say you have a fuse about a foot away from the battery under your hood. What happens if the wire is pinched under the vehicle (assuming that the cables are routed under) and touches the body? Well the fuse under the hood makes sure that more than a certain amount of current doesn't come from THAT battery. But what about the batteries in the back? Current can also flow from THAT direction too and your car will STILL go up in flames.
So things should look a little like this
[FRONT BATTERY]---{FUSE}=============================fully protected wire===================================={FUSE}---[bACK BATTERIES]
makes sense sean?....sorry for the lecture. lol
Dont worry bout the lecture, it makes perfect sense. im always so cheap i dont like to go buy fuses but i need to lol.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
does make sense! i see what you mean! so running wires under the car you should definately fuse both ends.. especially if you have battery at both ends..
I dont have battery at both ends, but im sure i will eventually when i get the moeny! lol..
06 SCION tC
I have mine fused at both ends. I can't take any chances even though they are inside the truck.
BlockShaker's Competition Page and Build-Up Pics
MY SET UP:
Eclipse CD5435 CD/MP3 Player
Alpine DVE-5207 DVD Player
Alpine PKG-1000 10.2" Monitor
Alpine TUE-T151 TV Tuner
Boyo Back Up Camera
Alpine ERA-G320 EQ
Apple Mini Ipod
Scosche RF Wireless Remote for Ipod
Stinger Volt Meter
Audiocontrol MVC
Precision Power PCX-2400
Precision Power PCX-4125
MB Quart Premium PCE-215 (2 Sets)
MB Quart Premium 6 1/2" Mid-Bass
JL Audio 15W0-8 (8)
Stinger Battery Power2 SP1000 (2)
Stinger Fuse Blocks, Holders and Distribution
Alumapro 15 Farad Cap
Stinger 200Amp Relay
100 Blue LEDs (Headliner and Amp Rack)
Stinger Hyper RCAs
Stinger Wiring- 1/0 GA, 4 GA, 8 GA, 10 GA, 12 GA and 14 GA
5 Blue LED Toggle Switches
  • Who's Online   0 Members, 0 Anonymous, 4497 Guests (See full list)
