I was wondering if you've tested th sax1200d, I'm putting it to 2-sa12's...
IIRC it did rated power with a rise to 2 ohms, or something along those lines. It was in a thread a while back, possibly the thread Jacob started when it first came out.
Edit: I found the thread. Here's Jacob's quote:
Two Stinger SPV-70 Batteries / 40-amp Power Supply / 8 awg wire power and Ground (this amp should have 4 awg)
Wired to 1 ohm nominal :
1170 Watts @ 12.5 volts
1.97 ohms after impedance rise
Wired to 0.5 ohm nominal :
1490 Watts @ 11.1 volts
0.85 ohms after impedance rise
Measured with my Extech True RMS power clamp meter several seconds into the tone @ 60 Hz -- this typically reads about ~15-16% less than a "dual peak hold" amp clamp test.
We'll do some more testing with a more adequate power wire coming up soon. The test bench 4 awg has the ends tinned so is a bit too big to go into the SAX-1200D terminals -- will need to get it in a vehicle.
Edited by R_Mac_1
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
Thanks guys! So it should do fine with 2sa12's until I jump to the 1500d
ah, how did you come up with a power figure for one of those amps if you didn't measure thee output voltage or current?
your tests seems rather flawed to me.
The Extech calculates power (watts) automatically without separate voltage & current readings. It is a very nice and accurate meter.
I'm pretty sure I know how to clamp amps :drink40:
In any event -- this is the meter :
http://www.extech.com/instruments/product.asp?catid=14&prodid=109
When compared to traditionally utilized separate meters this meter reads lower 99% of the time as the meter captures the actual power at any given moment. Separate readings can have a time variance; especially dual peak-hold which can be drastically off.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
  • Who's Online   1 Member, 0 Anonymous, 610 Guests (See full list)
