Being into racing for years. Anytime the temps are over 90 degrees the track wont hook right causing slow times also causing your car to run really hot. The ideal outside temp for racing is 65-80 degrees for exceptional performance. Track preparation also plays a big part in performance
Team MaxRetribution
Si Vis Pacem Parabellum
what was your 60' time?
that will say it all
I'm going with driver as well. Not saying it to be a dick, but your timing (reaction time) at the light among the fact of how many times you have ever drag raced and used that car to drag race. Post your times up...all of them. It's not uncommon to see a difference in your time vs what the car is suppose to do. The people who test them do it for a living..times will vary +/-.
I had my Lighning do a 12.2 and my friend who had been drag racing for ever got in it and ran a 11 flat (after a few runs). My reaction times were BAD! haha
10501650_10203332501847103_1859383749711
Blown
Would it surprise you if the factory ratings were a touch inflated? They use the best performance #s that were done under the best possible conditions.
As fro the track conditions temperature, humidity, and especially elevation play a big role in track times.
There tests are done on their tracks, and done below sea level so you get more power for having a higher air pressure than 14.7 pounds per square inch, which will yield the car more power.
¿ǝɯɐƃ ǝɥʇ
Reaction times have absolutely nothing to do with E.T. it is simply the time it takes you to roll out from the staging bulbs to the actual timed track, Staging shallower will yied better ET's as u have more roll out giving u more speed before you hit the actual timed track, But staging deeper shortens the roll out and causing faster Reactions an slower ET's. :) just though i should clarify that.
2000 White Dodge Durango 5.9L
Flowmaster 40 Series through 2 1/2" with and open cat.
1 Dc lvl5 18
4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2
Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire
shootin for 145+ :)
And some of my fastest runs have been on a track pushing 130 or so degree's, but track prep is a big key.
1 Dc lvl5 18
shootin for 145+ :)
  • 3 weeks later...
Reaction times are how fast you react to the light turning green without red lighting. Your e/t is the from the time you move from start to finish.
That could get interested with her potential positions, this being one of the better.. As soon as we started getting into it though, I'd have to toss her a serious taint/balls teabag from hell though with her head right there.-Marlo Stanfield
2 RE Audio SX 18's
Audiobahn 2200 Amplifier (soon to be upgraded)
14.34cuft@33hz enclosure
JVC kdr600 headunit(soon to be upgraded)
Big Three Performed
(upgrading alternator and adding more battery power soon)
Are you spinning off the line? I don't know how old/worn your tires are but if they are not in good shape and you are spinning, you won't be accelerating as quickly. x2 on the 60' times, let's see them!
Too many projects, too little time...
