I need a quick rundown on what the difference between passive and active. Passive is being powered by the headunit???? and active is powered by a amplifier? Maybe i didn't hear right but i want to make sure!
03 350Z
iirc in a Active setup the crossover is between the HU and amp. in a passive setup the crossover is between the amp and speakers
"Audio is not a hobby it's a lifestyle"
_____________________________Refs_1_Refs_2_____________________________
Kinda, but it's a little different than that.
An active setup uses a digital crossover or head unit with a digital crossover to set the parameters for the speaker system. A passive is a built crossover with analog parts that work in the same type of way but are limited by what they can do. Active can be adjusted to the user's exact preferences and passive is prebuilt and determined by the crossover manufacturer.
I may not be right on the money with my description either and I'm sure there is someone out there that can eloborate more, but for the most part it has to do with digital and analog.
Here are some deffinitions for you that should sum it up:
Passive Crossover: A crossover network dividing the frequencies without any active amplification or buffering components and which uses only resistors, capacitors and inductors.
Active crossover: An electronic crossover which uses at least one active device for gain or buffering.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
so basically active would be running an amplifier and passive would be runnin of the headunit? sound about right?
03 350Z
I run my components to a xover then to the amp, and i can mess with it on my head unit so im doing both ? ?
ever heard of google?
Active xover vs. Passive xover
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
^^ this guy ha ha. I hope i don't see your ass asking for help. Wait im sure you know everything. You don't need help. This forum is here for this reason. I searched. Yes i did. Obviously i didn't find anything under the search results with your name on it. I forget YOU use GOOGLE!! "Ever heard of google"... ha ha your great. Thanks for the help man. You definitely wasted two minutes of your time quoting and responding to the post. Im sure google could use some customer service. Call them they may be hiring. You would be their number one candidate.
03 350Z
one of the great things about running active is that the amp will only amplify the frequencies you need ;)
EDIT: and yest this question could have easily been searched.
Edited by finkster
Eclipse cd7000
Examples:
Active xover:
Passive xover:
I just remember that active you can adjust and control and passive is normal fixed to a certain cut off frequency.
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
