12000+ watts rms going to nothing now "NEED NEW SUBS"
Those PA3000DB amps have been proven over and over to do pretty damn close to its rated power at 14v, hes got almost 16v, and its still not doing 3000rms per amp?
They are actually tested at 2400rms IIRC at 1ohm, thats why I bought these amps too, and why so many other people bought them. Its a widely copied amp board that a lot of companies used, not a Power Acoustic amp board AT ALL
Big misunderstanding on that
Naw
turn radio up on high volumes (not max tho). To find the true rms rating of a amp take a volt meter put the neg and pos on the speaker output or run speaker wire through the current clamp from the speaker output of the amp. From there you will get a read out. You take that read out and square it. Once you do that you divide that squared number by the ohm load you have your amp at. Once you divide that will give you your rms rating of that amp at that ohm load
my amps have been tested with a volt/ current meter.
The findings with volume on 30 (max is 35) are as follow...
current output from amp was 56.2
you take that 56.2 and square it. You get 3158.
Then you divide by the ohm load you have the amp at (mine was 1 ohm). So I did 3158/1=3158, which is my rms wattage at 1 ohm.
Now I wont say that all PA amps can output like this one can but I have gotten good number off of different spl mics all btw 150 to 151.2 DB
3kw through 160a fusing? BS
I honestly dont understand why the amp is called the PA3000Db , when its rated on the box 2300rms
I think they claim 3000 max, but max is way over that?? I don't know
but its 900- 1000@4ohm 1800@2ohm, 2300@1ohm
That fuse would blow really quick eventhough he has high voltage. I`d say maximum 2500 with around 15 volts through a 160a fuse.
Proud member of SMD
My build log
2 DDZ9518
2 DynaBel BF 8501
2 GZ Neo 8"s
154.5@38hz with 2 DD Z9518`s
145.5@40hz with 2 DD 1508`s
My youtube vids
http://audioforum.termpro.com/topic/20/13128.html
thats from the man himself look for the post from snafu you may know him. had a hand in building some pretty cool stuff.
http://audioforum.termpro.com/topic/20/12106.html
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Because that's the name of the amp. PA3000Db, not PA3000Db watts, that's where most people go wrong, they look at the numbers in the name of the amp and think it's suppose to do what it name says. they need to look at the rms ratings. but 2300 watts , for the price isn't that bad (dollar/watt),
i love this sh--t man 1966 Ford Fairlane Pioneer prs 80, the big three, with 2 big azz agm batts, dual 270/200 amp alts , two 8'' mids and tweets in the kick( PPI phantom 600.2). two 10''s and tweets in the doors, two 10'' mids and tweets in the rear decK ( Lanar opti 500x2). 2 C2 Audio Threatcon 4 12s on a Crunch GP3000d. No crossover .
  • Who's Online   0 Members, 0 Anonymous, 957 Guests (See full list)
