whoever said Aluminum is louder?
I can name the 3 subs that have hit the highest scores ever in the world, and all have copper coils.
There are trade offs to each and loud and SQ has more to do with soft parts and design.
But as far as the AQ, I am not sure how they perform.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
just curious, what are the three subs?
DD-99Z
Shocker Brazil
Pioneer Premier
Ed Lester
ShowtimeSPL Host
My old Build Log
so would 2000watts blow the copper coil
my Level 5s have copper coils and im throwin 3k at them and there doing fine..
NoFearX18 said:
trainman0978 said:
I read in "Advanced speaker designs" from radio shack, a book I bought years ago that performance was dependant on how the soft parts are balanced. If you had too much weight on the coil side it could bottom out and if too much on the surround, cap, and cone side it can come out of the magnet easier and have less control. A balanced speaker whether copper or aluminum would have great control if it's balanced weight wise.
But ya do gotta admit they do get warm pretty quick. i mean mine hasnt had a problem with the 2600 or so im throwing at it. but it does get warm, when i jam on it for more than a few minutes.
2000 White Dodge Durango 5.9L
Flowmaster 40 Series through 2 1/2" with and open cat.
1 Dc lvl5 18
4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2
Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire
shootin for 145+ :)
I dont know of a speaker that dosent get warm after a few minutes of hard playing
All of the answers are correct stated
1) heavier, causing lower Fs
2) aluminum dissipate heat better, but copper can hold a pretty high temp
3) copper is a muh better SQ style coil that is for sure
but also not listed is that toe to toe alum vs copper, all the specs change, since copper has a much lower resistance, if you use the exact same coil specs, wire gauge, layers, winding width, lets say 2" ww, on a 3" coil, 4 layers 20 gauge
the copper will probably be about D1ohm, while the alum would be a D2-D3ohm
The copper will have a Bl about 3 times that of the aluminum coil say 20 alum to a 60 for the copper
The qts and qes change night and day, and vas will probably be cut in half of the aluminum
So all in all, if you like great sound from a smaller box, go with copper
another guy to ask about copper vs alum, I think was Jacob, he was telling me how he did some testing of copper vs alum coils... I have done testing between the 2, but it wasn't the greatest comparisons
exactly but just the way he worded it sounded like they have no heat or anything at all, just wanted to clear that up being that i run a lvl5 18. And its not just a luke warm, its pretty dang hot, hasnt effected the sub at all though thing still pounds away day in and day out. And thats with the cleanest signal i can get out of my amp.
And forevrbumpin is corect from what all ive read on the differences.
Edited by Moore941
1 Dc lvl5 18
shootin for 145+ :)
