andreg3000 Posted October 1, 2009 Report Posted October 1, 2009 Probably a stupid question, but would it be better to do 1/0 gauge 2 runs pos vs 1 run of pos & neg? Currently have 200A mechman & D3400 up front, 3x D975's in the back. Just ordered some more 1/0 to do an additional run but don't know if voltage drop / charging would be better with a particular setup. I know ideally, you should have equal runs of both, but if I could only add one more run what would be the best setup? Thanks Quote
troy Posted October 1, 2009 Report Posted October 1, 2009 it never could hurt you... Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Torres Posted October 1, 2009 Report Posted October 1, 2009 it wont hurt. but you're also only as strong as your weakest link, so it may not help either. Quote
andreg3000 Posted October 1, 2009 Author Report Posted October 1, 2009 it wont hurt. but you're also only as strong as your weakest link, so it may not help either. Ture, very true. Now if I do add the 1/0 neg run, should it be from the alternator mounting bolt, or from the front battery neg terminal? BTW big three also done already Quote
Saltine Posted October 1, 2009 Report Posted October 1, 2009 you dont need a full run of 0 guage ground to the back. your just wasting wire and money Quote
andreg3000 Posted October 1, 2009 Author Report Posted October 1, 2009 you dont need a full run of 0 guage ground to the back. your just wasting wire and money This is what I initially thought and was therefore gonna do the extra run of positive and just beef up the rear grounds at several different points. But I have always heard its ideal to do equal runs of both. I don't want to waste $80-$100 on adding something that's not worth the improvement. Anyone else want to chime in?? Quote
Crump Posted October 1, 2009 Report Posted October 1, 2009 Ture, very true. Now if I do add the 1/0 neg run, should it be from the alternator mounting bolt, or from the front battery neg terminal?BTW big three also done already If I recall Correctly the alternator bolt is on the best grounds on the car, but either one will work. I have always been told to keep the runs even, so 1 + 1- or 2+ 2-. Quote Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Hostility Posted October 1, 2009 Report Posted October 1, 2009 If I recall Correctly the alternator bolt is on the best grounds on the car, but either one will work. I have always been told to keep the runs even, so 1 + 1- or 2+ 2-. i really dont understand why people even run a neg run from the hood to the back. aren't grounds supose to be as short as possible? why not do 2 short grounds from rear batts to the frame, and 2 runs from the front battery??? seems like a waste in money to do neg. runs from the front. Quote 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
EricM9104 Posted October 1, 2009 Report Posted October 1, 2009 i really dont understand why people even run a neg run from the hood to the back. aren't grounds supose to be as short as possible? why not do 2 short grounds from rear batts to the frame, and 2 runs from the front battery??? seems like a waste in money to do neg. runs from the front. go through and factor in the resistance from the ground in back to the ground up front... Quote 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
Nightshade Posted October 1, 2009 Report Posted October 1, 2009 If your car is one continous chasis then you don't need to run a ground at all from the front to the back. The reason for competitors doing this is because their car's either are a split chasis or have a break in the body so they run a ground from the front to the back to keep the same ground for everything. If your car doesn't fall in this category then your okay to not use one of the runs for a negative and are better off to use it for a positive. Quote 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
