FS: Small Right Angle Brackets - $10 per lb
There are about 38-40 per pound.
Do you know how many are approx. in a pound?
DC.jpgDC POWER
shipping quote and preferred shipping method for 2 lbs please.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
How large are the mounting holes?
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
and the hole is just under 1/4" -- they are 3/4" wide (19mm
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Ok you talked me into it. How much shipped to 71742?
If you used a short screw ( maybe a half inch or so of threads ) with a large cap head on it, and then resin over it, it should be great to use under fiberglass. With the little bit of thickness of the bracket itself, and using 3/4 MDF you shouldn't break through the other side. Plus, you could always add a little glue on the back of the bracket before you screwed it down if you want a little extra holding power. Really though, you could prolly just put a little resin down, lay the bracket in , and cover it with resin soaked matt. If rope stifffens fiberglass, these should be twice as strong.....
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
I crammed 33 lbs into a USPS Medium Flat Rate box for someone... I will give 20% off to anyone wanting a Medium Flat Rate box full. Or 10% for a small flat rate box.
I will have to stuff them in and weigh them to see how many that is... depends on how well they compact as I just throw em' in :)
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
