Hunters21w Posted October 14, 2009 Report Posted October 14, 2009 9518s look BEASTMODE. What kinda power are those M3 amps puttin out? good luck mayne 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
onlyinajeep Posted October 14, 2009 Report Posted October 14, 2009 600 watts at 4 ohms TEAM PURE Team South http://www.stevemeadedesigns.com/board/topic/195192-8-pure-audio-15-flat-wall-chevy-crewcab-dually-vid-page-4-s/
sweet&low Posted October 14, 2009 Author Report Posted October 14, 2009 Series- M Model- M3a Input Sensitivity- 0.2V - 8V Variable Subsonic Filter- 10Hz - 50Hz @ 24dB/Oct Variable Low Pass Filter- 20Hz - 200Hz @ 24dB/Oct Clipping Display- LED Tested Voltage- 11.9 VDC Tested THD- ≥1% Cont Power at 4 ohm- Who cares? Cont Power at 2 ohm- 1365W x 1ch Cont Power at 1 ohm- 2400W x 1ch Dynamic Power 14.4 VDC- 3700W x 1ch Dimensions - mm- 546.1L x 232W x 63.5H Dimensions - inches- 21.5L x 9.13W x 2.5L Signal to Noise- >100dB
Cuseikan Posted October 14, 2009 Report Posted October 14, 2009 Holy shiza this is going to be bad ass!! Sorry if I missed it, but what batteries are you running? And don't worry about your motor pulling all of that weight. I had Well over 500pounds in my stock daily driver crx. The acceleration was lagging but it still got around and got 40+mpg. But then again the highest hills I ever had to go up were freeway entrances. I wouldn't suggest all that weight if you lived in a area with a lot of hills.
Hunters21w Posted October 14, 2009 Report Posted October 14, 2009 Dang tested voltage is 11.9? thats whats up. Im sure the 9500s will be very comfey on that. nice equip! 06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
sweet&low Posted October 14, 2009 Author Report Posted October 14, 2009 Holy shiza this is going to be bad ass!! Sorry if I missed it, but what batteries are you running? And don't worry about your motor pulling all of that weight. I had Well over 500pounds in my stock daily driver crx. The acceleration was lagging but it still got around and got 40+mpg. But then again the highest hills I ever had to go up were freeway entrances. I wouldn't suggest all that weight if you lived in a area with a lot of hills. Live in Florida flat as it gets lol. Ya with the weight it doesn't go anywhere quick got roughly get 35+ MPG in city get around 50 on highway with last setup has stiffer springs in the back.
sweet&low Posted October 14, 2009 Author Report Posted October 14, 2009 Also need some help here Fiberglassing the door and the glass just comes right off when I pull on it. It is all sanded with 40 grit then used alcohol take make sure there was no oil or grease on it. Need some help I am out of ideas never had this problem before. Anyone else have an idea. Thx for the help in advance NEED HELP WITH THIS ^^^^^^^^^^^^^^^^
treossi Posted October 14, 2009 Report Posted October 14, 2009 awesome!!!!!!!!! Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
baggedon4s Posted October 14, 2009 Report Posted October 14, 2009 Also need some help here Fiberglassing the door and the glass just comes right off when I pull on it. It is all sanded with 40 grit then used alcohol take make sure there was no oil or grease on it. Need some help I am out of ideas never had this problem before. Anyone else have an idea. Thx for the help in advance NEED HELP WITH THIS ^^^^^^^^^^^^^^^^ holes. many of them.....take a bout a 1/8th in drill bit and drill a ton on holes in the plastic where the glass meets the plastic. When you lay up, push the resin through the mat and into the holes. It will mushroom on the back side, and keep the panels on. A little two part epoxy around the edges (40/40 or something like that, that sticks to glass and plastic) will keep it from cracking. unless your gonna wrap them, then you can leave out the epoxy 99 suburban, ranger rover headlights, SS front bumper,roll pan with frenched tag, 2nd row delete,glassed dash..audio to come whenever I figure out what I want.
B Slaps Posted October 14, 2009 Report Posted October 14, 2009 either that or CA glue the shit out of the glass to the door panel. my homeboy C45 is a super fiberglass expert. I Rock 4 Doors 4 More Whores! SMD SUPER SELLER my seller feedback http://www.stevemead...-mama-feedback/ more seller feedback http://www.stevemead...-slaps-yo-mama/
