Where is the best/cheapest place to pick up copper 0 gauge wire? Ebay has kits for about $100, what are some other options?
Edit: I was also wondering if you all could look over my system and tell me if everything makes sense. I'm going to order it tonight and don't want to buy the wrong thing.
15" Fi Bl
AudioQue 1200d
KnuKonceptz Kolossus 0 gauge flex wiring kit
Pioneer AVH-P3100DVD
Big 3 upgrade under the hood
(I am going to add some speakers in the future, not really sure what I want yet, but thats at the bottom of the list right now)
Does that all sound good or am I missing something?
Edited by RedJay
2007 Black Tahoe
AudioQue HDC3 15"
AQ 1200d
Just go through Knukoncepts, they have pretty much everything u need and for the price it can't be beat. Plus the quality of the product is undeniable.
Pioneer AVIC-N2
Alright so i was reading up on the link above and its CCA (copper clad aluminum), which is 90% aluminum and 10% copper. I am pretty sure thats not what i am looking for. I thought 100% or the closest I could get to 100% were the way to go. Im right arent I? And what size fuze should i need if i order from KnuKonzeptz site? Can you get TOO big of a fuse?
2007 Black Tahoe
AudioQue HDC3 15"
AQ 1200d
Depends how much RMS power your going to be running 80 amps should be fine with under 1000 watts. With 1500 I'd probably go with 120-150 amp fuse.
http://www.stevemeadedesigns.com/board/ind...?showtopic=1005
Also the AQ1200D does not accept 0 gauge, the biggest it will accept is 4 gauge. So if you go with a 0 gauge kit you'll need a reducer for the amp to accept it. And btw I only run 4 gauge kolussus flecks to the back to my extra battery and amp, and it works perfectly fine.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
I run 1/0 to aq 1200 and I have yet to find a reducer that will fit in the power and ground holes. I just trim the wire down a bit and all is good
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
