Burb Build 4 18" Re X X X 150++ Daily Driver!
the two runs of wire are just from the front battery to the rear where I am putting two more where each amp will have its own seperate connect (no distro blocks) to the batteries. those runs will be less than 6ft so I shouldnt have any probs for just daily bumpin etc....
Do you have an H/O alternator? That's what my question was really geared toward. Because before your amp gets current from your battery, the alternator will be the one providing the current...until....the demand gets too high and the voltage drops. This is where the battery kicks in. I was referring to the instant when your battery hasn't kicked in...if you have an H/O alt (can't remember if you said you had one) do you think 2 runs are enough?
Edit: I'm asking more for myself because I plan to have an H/O alt and I was wondering if just 2 runs of knuconceptz would be ok or if 4 runs would be better, since there would certainly be less resistance
VERY NICE!!!!
Follow my Tweet (Twitter)
I connect all the amps to the last battery in line. I dont think it would be a good choice to connect a seperate amp per
battery due to charging issues. ( the last battery may never get its full amount of charge)
Thats kind of confusing me a lil bit then.
Like Dale, I will be running a multi battery setup soon too.
I will probolly be having at least 6 batteries in my trunk too power two amps.
So you DO you want to connect the amps to the last battery?
Or do you NOT want to connect the amps to the last battery because the last battery may never see a full charge?
Would I just ground my amps directly to the battery and not worry about grounding the amps out to the body since the batteries would already be grounded through the body?
Just trying to clear up any confusion
Here is a diagram on what I was planning.
3 runs of pos and neg from front to back.
Posted Image
My rear batteries are going to be grounded to the chassis just like the one under the hood. then I am going to connect my amps to the last battery in line. If you are going to use a bus bar set up then you can hook the amps to the busbar and anywhere in the line is o.k. I am not using bus bars just wiring them up in parallel. but the diagram that you have is just fine and shouldnt give you ant trouble.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
Thanx steve, thanx .....visitor?? :blink:
here is what I did last night.......
one t3000Posted Image
and one XXX 18
Posted Image
in a 9 cube enclosure with a 3" x 19" x 7 " long port tested some music to get a feel if my final calculations would be worth all the effort.....( wouldnt it suck if I did all the work to the wall and had to tear it out) then put a slightly bigger 5 x 19 x 9"
anyway......IT BANGED LIKE A MOFO!!!!!!!!
I am taking tonight off and will continur on it tuesday night after work!
Scientia est Vox
I have a ohio generator on the way and will be installing that also. on the runs of wire2 runs should be plenty as long as your running 1/0 or higher
Scientia est Vox
That is FVCKIN crazy man. Keep up the good work.
You lika da juice??
O I bet you do...
Gathering stuff for my new car:
Sub: 1 Solo X 18"
Amp: DD Z1A
Comps: 4 sets of RE 6.5's
Comp amps: 2 Infinity 7541a's
H/U: Kenwood DDX8017
Wire: 4 strands of 1/0 (2+ 2-)
Batteries: Yellowtop up front, 3 Batcap 2000's in rear
Thats alot of batterys. Looking good so far man.
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
my that XXX sub looks sexy
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
