Audiopipe FTW?(Real world clamp tests!)
Twistedchild420
yea seems numbers might be slightly inflated to me
wow those numbers are making me consider that thing for my new build, Im going to have 4 dual 4 ohm subs so I will have a 2 ohm load and I was thinking of just getting another aq1200 but those supposedly link for 2400rms@ 2 ohms... I wonder which is better
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
To be honest, we don't even know if they used True RMS DMMs. So we could be looking at peak output voltage. The power output seems too high... let me crunch the numbers...
2526 @ 4.2 ohms = 1263 @ 2.1 ohms per amp.
P=V^2/Z
2652 = V^2
V=51
51v @ output implies that with a true 2 ohm load the 2 amps would be doing around 5kw - and we all know those amps don't pull that kind of number...
If you divide it by 1.414 (RMS to Peak conversion) you get 1839w/amp which is probably a bit closer to the truth... IN FACT if you divide by 1.414 again you get right around 1300w/amp (non True RMS clamp meter) which is bang on what the factory test results claim.
So yeah. That's my input on that one.
this is what i have seen in several test ..i have seen done on these amps
well, if he got the ohm load down to around 2, and the volts up to about 14, i would say you would see almost 3500 rms,
It won't be doing anywhere near 3500w clamped watts @ 2ohm for reasons mentioned by Boon earlier.
P=V^2/Z
2652 = V^2
V=51
I agree 100%.. When I first saw the numbers they did seem a little too good to be true. If it really was doing 2500w @ around 4ohms a hell of a lot more legit competitors would be running these for the price vs power alone.
I'll see if I can find the numbers from when I tested one a little while back, but I'm pretty sure that it was around 1700w near 4ohms clamped.
Pioneer AVIC-N2
  • Who's Online   1 Member, 0 Anonymous, 1568 Guests (See full list)
