Early 90's car choices for under $4k?
How bout the fastest 4cyl in the world, Brent Rau's Eclipse, Eclipse body from the firewall back.
1400 HP
2200 LBS
11,000 RPM
86 PSI OF BOOST
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
since when does having a forged block mean its stock? the huber mustang has the original block PISTONS AND CRANK.. AND is daily driven.. It was named THE WORLDS FASTEST STREET DRIVEN CAR in 2008.. no 83lbs of boost car is on the stock block lol.. or daily driven. and by stock i mean STOCK just as it came from the factory not dipped not reforged STOCK.
and as for the mark's Yes they are an amazing block car... and there not better than the cobra.. They share the block and lack a few h.p compared to the cobra.. The teksid block which was made in itaily by the same company that builds ferrari's blocks (because ford couldnt make enough of them) has been known to push 1400rwhp (so roughly 1600 to the crank) without any mods to the block itself Great cars.. and will run forever.. we used to have one with a Kenne bell supercharger but then it got totalled :(
the lincolns lack the the same throttle bodies headers and a few slight changes.. But they are made the same way as the cobra's blocks at the time (96 and 97 were the only years that shared the block)
The set up your talking about would sound great in my Tahoe. Trade you my dog for it. He has one eye but that only makes for bad depth perception so hey so what if he is running into shit, look at it this way he is easy to sneak up ninja style on. (right side only)
</div>
I don't understand when this turned into a racing thread... he asked about a car under 4k I doubt he's gonna care about the worlds fastest street car
I did go for honda because those are good car and reliable on gas..
My Mark VIII got 15-17MPG in the city and over 25 on the HWY. And that was with a finnicky tranny (had to turn OD off in the city or it would stumble into OD too often) Not too bad for a 3900 LB car with a v8.
I know the motor is not identical to the Cobra, but it is very similar. Intake, heads, and a bunch of other parts were not the same parts.
I was under the impression that the Teksid block was only used in the Mark, and that it was in fact superior to the Aluminum blocks used in the Cobra. I think it was because when the Mark VIII came out it was the first car to use the 32V 4.6 (the Cobra didn't get it until 96) and by that time Ford had starting making their own blocks for the motor.
I remember a guy with the forum name Roadboss on the Mark VIII board who had a Kenne Bell and it was nice. There were a few other sweet cars floating around on there too.
Again, I'm no expert on this, but I'm just trying to remember all the crap I read on the Mark VIII forums a few years back. And, I guess all this crap really doesn't matter to the OP beings he is just looking for a DD.
Good luck with your search.
Edit: After a quick google search I guess it seems that Ford used the block into 99 and then started producing their own. Looks like they had leftovers and used them here and there into 01 in the Cobras. You were right.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
Dude its a 6bolt bolt block....it has a forged bottom end (pistons, crank, rods) also has a Kiggly Main Girdle...STILL ITS A STOCK BLOCK....
and I don't give a crap how "beefy" the stang motors are I wanna see a stock block (not sleeved etc) run in the 7s..... I don't care if it has a forged bottom end or not....
edit: Heres a STOCK 6bolt in the 10s...
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
