XS Power
x2 on the ford module ETA
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
how about a 93 stealth/3000gt base model? It has a mechman 150 amp alt in there if that matters. Thanks.
Eclipse cd7000
What year is it and what plug is on your alternator?
truck is a 96 it would take me removin stuff to get to the alt plug im sure mechman knows i was really lookin forward to buying one of these i didnt purchase an external regulator in hopes of buying one of these
Sorry, but the VCM will not work for that application. It will not work with the newer 2 pin GM applications.
Bummer :(
Thanks for getting back to me :)
Maybe next yr we'll get some xs power in the GP.
  • 1 year later...
What if I have a "voltage booster" like this that boosts the voltage by 1.2 volts? Can I still use it, or will I need it? If I can use it do I plug the VCM into that or to the alt, then the booster?
http://www.zzperformance.com/products_img/517_1.jpg
Pontiac Grand Prix GT
400a Mean Machine alt.
EIGHT DD 12''s on a DDz2
DD vo 8''s,6''s,5.25''s&tweets
Norfolk, VA
http://www.youtube.c...ser/ovnorfolkva
https://www.facebook.com/groups/TheSPLSpot/473815915987218/?notif_t=group_activity#!/chrishova
http://www.stevemead...__fromsearch__1[/color]
sometimes i like my vcm sometimes i dont my bottom button doesnt work half the time so i cant adjust it to charge at 16v to my 14v batterys. can you post dip switch configurations for gm 4pin vcm on a 98 tahoe. also if i send it back how long to fix the button issue? realtime not estimated please. i have friends that have been waiting for months. not trying to knock xs at all i love your batterys but the vcm is faulty
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
is there a vcm for my 2005 ford mustang 4.0L V6?
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
So your voltage will not drop down? Don't have a real time to give you on it. Just have to send it in and see whats wrong with it and then work to get it fixed. Dip switch configuration depends on the version you have and should be on the instructions that came with it. If you need help with it just email [email protected]
