IH8PunkRok Posted February 9, 2010 Report Posted February 9, 2010 i seen a astro do 181.7 with 4 15's and 8 10,000 watt amps idk what it peaks at then i seen a astro with 6 18's and 24 4,000 watt amps do a 172.2 and broke his windshield i can guarantee thesewere nowhere near sub 30 hz (which is what this thread is about) -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
BenH Posted February 9, 2010 Report Posted February 9, 2010 i seen a astro do 181.7 with 4 15's and 8 10,000 watt amps idk what it peaks at You're probably speaking of Craig Butler. His extreme vehicle cannot be compared to a ground-pounder. 1992 GMC Sonoma 2008 MECA S1 Champ, 2010 MECA S2 Champ
BanginOnABudget Posted February 10, 2010 Report Posted February 10, 2010 my 33" jensen hit 9000 deebeez at 6hz. in a 12 partition usl sonowave enclosure off of five hundred twenty five thousand six hundres watts. do i win now? im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire. Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block.... 1990 Jeep Cherokee 2 Dr. Big-3 in 0g on Stock Alt. Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos. Pioneer 6000ub Reciever NO amps at the moment. SA-15 on 1kw coming soon. MSG Me for a free enclosure design!! Flared port kits coming soon!!
Neo_frog Posted February 10, 2010 Report Posted February 10, 2010 my 33" jensen hit 9000 deebeez at 6hz. in a 12 partition usl sonowave enclosure off of five hundred twenty five thousand six hundres watts. do i win now? pics or fail EDIT: Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
thebiggmann12 Posted February 10, 2010 Report Posted February 10, 2010 pics or failEDIT: pretty sure fail anyways.
uhoh_45 Posted February 10, 2010 Report Posted February 10, 2010 my 33" jensen hit 9000 deebeez at 6hz. in a 12 partition usl sonowave enclosure off of five hundred twenty five thousand six hundres watts. do i win now? a shot on the nuts R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
assman Posted February 10, 2010 Report Posted February 10, 2010 I was able to get a 154 at 20 hz Assman IdustriesFear The DuckTeam Notoriously Loud Mafia
czman30 Posted February 10, 2010 Report Posted February 10, 2010 I was able to get a 154 at 20 hz what's your system consist of ?? Introduce a no fat chicks in the whip rule. Im gonna have tech force make up a sign that says that and put it on my car lol
