9.75mm xmax on Kicker Comp C12?
Sounds about right for that particular woofer.
Pioneer AVIC-N2
9.76mm. Jesus. Must be heaps better than all those woofers out there with only 9.73mm.
Don't get hung up on specs like xmax. It's probably the third-most lied about spec, after power handling and sensitivity.
10.x volts fo' life!
xmax is almost pointless to rely on
especially in a ported enclosure, where at tunning, the sub barely moves at all
xmax is more important in sealed if anything
Thanks for these informations!
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
OK OK someone needs to tell me how to put one of those Quote bubbles in my sig cause I thank this is sig worthy to me. LOL
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
LOL and to just let ya know that sub will shock the shit out of you for the price. LOL LOL LO D da
  • Who's Online   0 Members, 0 Anonymous, 962 Guests (See full list)
