Check it out!
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="500" height="405"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="500" height="405"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
-Drew
Edited by Noobtastic14
uhoh_45 said:
you went from 145db @44hz when I first met you....
....to 155.4db @37hz as of tonight
I'd say your making pretty good progress :yahoo:
-Drew
damn kids and there toys
you should teach me how to get loud
Why? Apparently you've taught everyone else and built every combination out there, so you would have nothing to learn.
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
lollerskates
DC.jpgDC POWER
all hail the true KING OF BASS
R.I.P!
(Nov-29-2009)
92 explorer
current build
