XS Power
Nathan, im gonna be 12krms DAILY...Honestly how many D3100's you think I would be good with....? Seems from your chart I would only.need 2D3100's... but that's not right lol
He rates the D3100s at 2500wrms for comps and 5000wrms for daily systems. I prefer using math though. What alt(s) do you have?
1 DC power 270sp but was custom built.from rob... does 198@ idle....
and This for a Warhorse... my plan was.... to put 1D3100 under the hood and use that for the starting battery and for my 4channl & accessories... then 4D3100's in the back dedicated for my Warhorse only...
I think you'll be fine with 5 d3100s. The tech behidn the warhorse keeps current draw low. its got a max draw of right around 800 amps give or take. thats a third less than I have for the same power. I thought you were doing two?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Posted (edited)
I didnt see this post..my bad :shrug:
Youll be set with that setup :) Id add another one. I like overkill though :lol:
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Posted (edited)
What's the difference between the S1200 and the D1200 and will those batteries fit in a factory battery space? Will I harm my alt if I get a 14v battery instead of a 12v?
Edited by Crich03
Woofer:Fully loaded(3inch coil)15 inch Fi BL 4 cubic ft box tuned to 32hz
Bass Amp: Audioque 1200d(just purchased a Sundown Audio SAX 1200d)
Highs/Mids Amp: Alpine PDX 4.100
Door Speakers: Alpine Type R and S 6.5's
Vehicle: 2008 Mazda 6 stock alt and soon to be XS Power S1200 0gauge ran from batt to cap and 4 gauge to both amps
S1200 comes with battery posts D1200 doesn't.
Oh cool thanks
  • 1 month later...
Will stock alternator & starting battery with a D3100 in the back run a 3200w system for a month or so (it would take me a month extra to upgrade to HO alt...)?
I'm a novice with all of this, so thanks for any replies and information :D
Posted (edited)
Would definitely not want that to happen... Damn car audio is expensive, but it sure is fun...
Do you think a 180amp alt would hold well enough? My local shop gave me a price of $250 or so for one...
Edited by Supercharged DDs
quick question, im gonna be running an audioque 2200d, big 3 in 0awg in a 2000 passat w a 120amp alt with amp running at 2 ohms, what battery would be best for me if i only wanna replace the one under the hood, biggest size i think i can use is the d2700, so would that bee too much or a good idea, and also, when you buy the batteries from say mechman, do they come with the posts for the battery or do you have to buy them?
You cant put to big of a battery in there, so if you can fit the D2700 then I would put it in there. You would need to check with the dealer to see what they put in the batteries for you, but the D version of the batteries do not come with terminals from here.
