my small crx spl build
Im not going to say 15s wont work, but the most success has been with alot of smaller woofers like say 6-10s
What on earth are you on about? If I recall correctly the loudest CRX on the planet runs 4 12's. But there's some pretty damn loud ones running 2 10's
10.x volts fo' life!
because to tune lower youd need like 8ft of pipe
tubes are also really good for 4rth orders = musical :P
R.I.P!
(Nov-29-2009)
92 explorer
current build
57Hz you say? soo this things sounds like poo on music? no offense im just deciding if im gona tune my next box high for the meter or keep it low so its loud with music
when i have all my ports open i am tuned to 57hz..and YES, ALL music sucks!
42-45 is cool if you don't do screwed/mega low bass, stuff like lil wayne, eminem and still burps good
35 down for screwed/slowed and like LOW bass , will move ALOT of air and flex like crazy...but weak burp(usually-not always)
1996 GMC YUKON 2dr
Eclipse cd5000
six- Soundstream T5 12's in 13^ft tuned to 30.4hz,43.04hz, and 53.53hz soundoff
149.8 on TL in kick,150.0 SEALED in kick 147.8 SB4
3 RF T5002's--------------going to 3 Soundstream DTR1.3400D's
two- Stinger sp1000's----going to two- BATCAP 4000's
2 140 amp alternators---going to 300amp Ohio Generator
2 runs 1/0ga, big 3-------going to 4 runs 1/0g + and 3 runs 1/0g -
MB Quart QSD 6.5's in doors---soon to come
my build log HERE!!!! check it out!
its nice seeing a CRX that isnt a one note wonder
looks loud
edit read tuned to 57 hz BOOOO
if you tune a crx low . you will do nothing for numbers and get laughed at. dosent mean my rex tuned at 55 hzs with music boxes wouldnt play 40 hzs music.
If u really wanna go all out with the SPL side in the Rex, then I'd suggest making sum tubes for the woofers.. You'll see most of the loudest CRXs(also similar lower SPL class vehicles worldwide) around using the tubes now and are extremely successful doing so.
this is true. i have said tubes at my house.
you can hang it out the back like a rocket. thatll sure impress someone right?
I Rock 4 Doors 4 More Whores!
SMD SUPER SELLER
my seller feedback http://www.stevemead...-mama-feedback/
more seller feedback http://www.stevemead...-slaps-yo-mama/
i think its cool to see some spl builds how do you make the tube boxes? i have a dd 2515 and would like to give it a try
like this
edit
R.I.P!
(Nov-29-2009)
92 explorer
current build
6 10s hmmm :01nocomment8so:
this was in the 0-600, but I didnt get a full run. Once I started turning it up a relay under my dash which was hanging loose rattled apart causing the car to die which sucked so I got to a 151.6 so it was whatever. By the way its steven spencer not pencer the camera cut it off.
