Big Als Hifonics 20kw 24 woofer install..
Ok guys had a measure up i have 20 cuft for rear cab sealed and 45 cuft for front cab ported side plan is to start with a 53hz port which rear chamber tunning is,then make a 38hz port which looks fantastic on plots ,if im honest id say maybe its a bit of a risk has i know what a trusted ported box will do,but i do like to be a bit different and there is more than a few installs that are out there at the moment that are doing fantastic with 4th order bandpass.what do you guys think??
I don't think I could bring myself to take a sawzall to what is in there now, its so gorgeous. But 4th orders are super efficient and people are really starting to figure them out, why a 2:1 ration instead of a 3:1? I see much more success as 4th orders approach the 3:1 ratio. I would send a few PMs to SSAudio, hes the master of all things bandpass.
Ive gone for 2.1 ratio because that leaves 0.83 cuft a woofer any smaller id guess then tunning will be too high and i wont get too much low frequency extension?? thats how i understand? i may be wrong if i went any smaller on rear seal box wont that limit how low it plays?If a 2.1 ratio is no good maybe a sealed bandpass may not b the best then! either way i have to use all 24 woofers :shrug:
The uk,s first 170db
wow bro i cant believe how good you are at this shit....
AMAZING - :good:
Follow my Tweet (Twitter)
I guess I didn't consider you keeping all 24 woofers. Even at a 2:1 ratio .83 cu ft per woofer is awfully small. I think with all the work already put it, and the amount of work and cost to do the bandpass. The numbers just aren't promising enough for me to tear it out. You can try it, and I will definitely watch, but I wouldn't do it. Not without sacrificing some woofers or finding more space.
EDIT: Then again, its still 20cuft of sealed airspace together. That is a tough call! I still say send a PM to SSAudio and see what he thinks. That is a lot of time and money tied up into a design with the potential of failure. Cancellation is a big problem with band-passes and you have a lot of woofers to deal with.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
this is godly! i love the colors and amazing job on the wiring, very clean! keep up the work
Vehicle - 96' Honda Civic Ex
Beats - Termlab - 132.2db at the windshield
Head Unit - Sony Xplod
Mids/Highs - Planet Audio Big Bang Components up front/6x9 rear
Bass - (2)Cross Fire P1
Mids/Highs Amp - Planet Audio RX400.2
Bass Amp - Planet Audio TQ1601D
the build was effin epic cant wait to see the updated version good luck with doin the 4th order
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
Cheers buddy thats helped a lot ,i have run the olm 2412 through bbp6 and it recomended 18.75 cuft on the sealed side with a qtc 0.707 flat alignment which gives a nice curve ,which then leaves me 45cuft on front chamber,i know the added cone area will play lower,i wanted to change the baffle after we change woofers ,i just was not happy with making spacers to make woofers fit ,it just dont have that finished look.
those doors are beautiful in there simplicity. and the whole install is insanely neat man :clapping:
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
