I think someone might have said it already, but why dont you use fewer subs say 4 and go ported.. I think you will have better luck and will be happier with the final product... But im glad you going away from the X.. Great sub just not for what you wanted to do...
HU...Pioneer 5900IB
Wireing...Stinger
Amps...(1) Modded Stetsom 2K6..
Batts...(1) Stinger 2150
SPL Subs...(2) DD 9515 Hybrids
Daily Subs..(1) Mmats P3.0 15
N.S.P.L.
2012 NC State Record Trunk 1801-3600
2012 World Record Trunk 1801-3600
2011 NC State Record No Wall 0-24"
2011 NC State Record No Wall 0-24" Hardcore
2011 World Record No Wall 0-24"
2011 World Record No Wall 0-24" Hardcore
2010 World Record No Wall 0-2500w
2010 NC State Record No Wall 0-2500w
2009 NC State Record No Wall 0-24"
2009 NC State Record No Wall Hardcore 0-24"
I did 4 12's sealed just a few weeks ago...went for the most woofers I could fit inside the cab 'cause of the looks
It was pretty loud... then I took a sub out to fix an air leak...and fired it up like that - with a hole in the baffle, and that was a bit loouder even at half volume. So I swapped in a 6" port instead of the corner most sub. I've got to say I'm a bit sorry I didn't build this box ported in the first place (it real restrictive inside right now with heaps of bracing) - It's nasty loud, and hits real low with 34Hz of tuning - way louder on the lows than the sealed setup
But in your case, sealed might work better as you have more cubic feet per sub
2003 Dodge Ram 1500 - Deep Orange
Build log - Blowthrought with 4 18's http://www.stevemeadedesigns.com/board/topic/122600-4-18s-in-a-dodge-ram-team-sundown-russia/
Sundown Audio SAX125.2 - Sundown PA 10"
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
Sundown Audio Russia
http://sundownaudio....dex.php?/index
http://www.drive2.ru...ram/ram/skillz/ - more about my truck
http://www.youtube.com/user/Gskillz81
Okay so im ditching the SOLO X idea, cause there's no way im gonna get 5000watts in my little civic right now. (Electrical)
Im in doubt between the 4 12's ported and 6 12's sealed. I want my stuff to be loud but sound good at the same time. (Flat response curve)
Maybe i should get 6 12s and make a sealed box at first and when i change my mind make it a ported box?
I want to know if the extra 2 12s' cone area would make a big difference!
Thanks for the replies people!
Pretty sure the 4 12s' port would make up for the 2 extra 12s' cone area....
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
do six 12's ported.
if you say you cant fit it your doing something wrong :P
lol that coming from you, im sure you're right. but walls just happen to be illegal in this country (blah!) so thats not really an option, otherwise i wouldve walled 6 to 8 12's already haha.
btw Love your ride man!
'99 Civic hatch
18" AA Chaos - 7cuft @ 34hz - 114sq in. port
Mac Audio Fearless ~ 1000wrms @ 2 Ohms
Videos:
Youtube
my friends shop did 4 twelves ported and it was very loud did the soundstream t5's I say four twelves ported
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
This is the right bad idea
"in the abundance of water, the fool is thirsty" Bob Marley
Which would you go for and why?
One 18" Solo X ported (lets say 7cft @33hz).
Four 12" subs SEALED. (something decent)
Six 12" subs SEALED. (cheaper options like MTX road thunder stuff)
Assuming all options get the same power! (2000 w rms)
Peace
EVENTHOUGH YOU'LL HAVE MORE SUBS ON THERE THEY WOULDNT GET THE LOWS AS A 18 SOLO-X WOULD, AND WITH ONE SUB THERE IS NOT MUCH HASSLE IN WIRING AND ENCLOSURE
Lows are dictated mostly by xmax/xmech and physical cone area.
18" solo x might not beat the 6x12's. Should be equal or better than 4x12's. though
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
