Z-5500 Sub replacement
So, Im tired of the way the stock z-5500 sub sounds. Its too boomy and doesnt sound good to me. Im considering taking the plate amp off the back and building a new enclosure with a new sub. Anyone got any sub recommendations? Id like to go with a 12 or 15.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
If the sub has enough output but is just too boomy, you can first try to adjust the enclosure. Thiscan make a huge difference and not cost you very much. Take the enclosure apart and line it the interior walls with 1/2" acoustic foam. then lightly stuff the interior with pollyfill. tune it a little lower by lenghtening the port or reducing its diameter. These little changes should help. If that doesnt do it you can replace the woofer, but at that point you might be spending more than it's worth.
Check out my caraudio builds.
http://www.stevemeadedesigns.com/board/topic/72104-scary-truck-rebuild/
Check out our Custom Home Theater builds @
www.SoundAdviceUtah.com
The placement of it in your room makes a big difference. Having the sub under my desk it sounds boom and shitty. But if I stand on the other side of the room, the sub does alright going down to 28hz. So maybe you should try putting the sub on the other side. Also, you can try and extend the port so it will lower the tuning since it`s tuned around 45-50hz.
Mids/Highs: stock Bang & Olufsen
Lows: Image Dynamics IDMax 12v.3
Power: Sony Xplod XM-D9001GTR:Knukonceptz 4 gauge
Box: 1.75 cu/ft Sealed
Past: Pioneer Premier TS-W1207 (2)/ Rockford Fosgate P210/ Image Dynamics ID10V.3/ Infinity Reference 311A/ Audiopipe AP-18001D
Hi to all this is William i from LO i just join this forum today..
hello, but what the heck has this got to do with his z-5500? lol :P
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
  • 3 weeks later...
recently my sub has been crap... barley any bass, highs are still loud as day one. think the plate amp is bad??? or does the amp push the sub and highs??
yeah the amp on the z5500 powers the whole system
hmmm... well the highs are still loud.
i also noticed, once i loaded windows 7, the audio was a little different. don't know if that has anything to do with it.
A good way to find good placement is to put the sub in your seating position, then crawl around on the floor and find where the bass sounds best. Wherever that place is, is the best place to put the sub.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
