hm cause nothing was sparking at all but ill buy some fuses soon and try again and ill take some pictures of the inside of the amp if i see something suspicious.
out of all the responses, best thing to do is
1) test light
2) Volt meter
That should have been the first thing you should have done, start testing battery connection, then fuse, then at amp, if no power, track it down. I would believe if anything the romote fried. Remotes only are capable of handling like a 0.5-3 amp load, pretty damn light huh? If all is good, THEM the amp is fried
Ive been installing since about 1995 and I can only think of maybe 2-3 times I ever disconnected the battery/ground when messing with amps, I always disconnect the fuses before touching amps.... But caps, batteries, or adding fuses, then I disconnect the battery
Also... it seemed you hinted toward that this was a used amp... so if it was... are you 100% sure it worked in the first place? simple question, but sometimes problems have simple answers.... :)
Edited by rusty959
well i hooked up my amp back to my car and everything was working but it sparked when i tried to put on the positive wire so i removed the ground from the battery and put it on and it worked.
glad that shit worked out for you
Subs- 2AA Arsenal 15sAmps- Orion2500d/MemphisDoors- Infinity kapa/AA polymids(soon)Deck- Pioneer PrimerBox- 3.5 per chamber!!!!!!!!/28hzElectrical- two optima red tops/160alt(big 3 soon)OHIO BABY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
take a jumper wire and run it from the + lead to the remote turn on making sure the remote wire from the deck is disconnected from the deck ;) if that doesnt do any thing you need to start at the deck testing every thing and working your way back to your subs
always disconnect the battery's negative before you connect wires bro. you will always see sparks if you don't.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
