Mosin Posted March 27, 2010 Report Posted March 27, 2010 Alt is a stock 100amp unit. stock batt up front. Big 3 has been done in 0g along with 0g positive run. Amplifier will be a Hifonics BXi 2610D. I plan only to play system with vehicle running, NEVER off. Will adding a 2nd help? I know I need to get a h.o. alt, etc. But this would be a temp set-up til I can afford a h.o. alt. The batt is a Everstart Maxx batt. 925ca, 725cca. up front is a reg. batt I believe a 625cca batt. Derp.
loganberry Posted March 27, 2010 Report Posted March 27, 2010 youll be fine, i ran 4 batteries off a stock 130, i still have the 130 alt and it works fine after 6 months My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
Mosin Posted March 27, 2010 Author Report Posted March 27, 2010 Logan, you think it'll somewhat stiffen the voltage? Derp.
J00bles Posted March 28, 2010 Report Posted March 28, 2010 Logan, you think it'll somewhat stiffen the voltage? it'll help the voltage a little bit, but with both batteries being "wet cells" you'll probably only see a marginal gain. You'd almost be better off replacing the front battery with the largest AGM you can fit and doing your run from that to the amplifier. NOW, i used to own that same amplifier, and i can tell you that your voltage is going to suffer quite a bit with the set-up you plan to run. My electrical is listed in my signature, and with the brutus amp i would fall into the low 12s or high 11s. my Diablo Audio Technologies 2500 amplifier doesnt even drop my voltage that low. look into 2 AGM batteries (big ones) and a new alternator. if you cant do the alternator, just set the amp settings a little easy... if you cant do the batteries or the alternator; kiss your dreams of running this amp, away. 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
newls1 Posted March 28, 2010 Report Posted March 28, 2010 I would stay away from mixing different "technology" batts, but other then that, adding a 2nd batt really would only help ya..... I love my staffie So anti FACEBOOK it isn't even funny
Neo_frog Posted March 28, 2010 Report Posted March 28, 2010 Each extra battery you add to your system draws ~2A for charging, so you should be just fine with your alt. Not saying it's going to fix your problems though... Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
trevtp Posted March 28, 2010 Report Posted March 28, 2010 Well when you think about your alt isnt make for making alot of power for subs..but it works though..so adding a second batt might have a little more power..but then there will be less power in the long run for the stock alt to keep up..just better be off getting a aftermarket alt.
solo_x18_mobile Posted March 28, 2010 Report Posted March 28, 2010 Just for the record this is a temp electrical set-up. I'm not trying to run this forever... Just until I can afford a H.O. alt and some AGM batts to replace these wet cells. j00bles - yeah. neo - Thanks for that info. newls1 - Is it personal preferance to stay away from mixing batt technologies? Solo Baric L7 - Imitated, but NEVER duplicated!!!
