A Young Canadians first enclosure build
how big is the sealed box and how big is the ported ? i'll try and help you out there too
R.I.P!
(Nov-29-2009)
92 explorer
current build
it sounds like the sub when the bass hits, that the surrounding of the woofer is hitting the port.
or that the port is actually flexing with the air and is making the sound
what size pvc is that?
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
I think it's a huge load of port noise, does the sound get's quieter if you turn it down at like volume 10?
It has the same "rattle" but not as violent
I believe it was 0.9cu.ft sealed and 0.6cu.ft ported
I took the port out and I think the sound is coming from the woofer itself or something else inside, I don't think its the port anymore
yeah your ported area is to small thats what it was you need anywhere from 2-2.7 cubes ported for this to work tuned to 60 hz
R.I.P!
(Nov-29-2009)
92 explorer
current build
just swap the port and the terminal cap so the ported section is bigger and the sealed is smaller and see what happens. may give a little more control on the sub
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
this. you can always switch it back
1997 Pontiac Bonneville Black on Black on Black
15" DC Sound Labs Level 5 w/ quad coil in a T-Line tuned to 35 hz
7" Jensen VM9311TS Touch Screen Flip Out w/ J-Link
Blue Custom Trim
Blue Custom Fiberglass Rear Speaker Pods
Autotek Mean Machine MM2000.1
1/0 Knukonceptz KLMX
Rockford Fosgate Twisted RCA's
2 Audiopipe Anl fuse holders w/ 200A Kicker fuses
2nd battery (Soon to be an Odyssey D3100)
Dynamat Extreme Bulk Pack
Custom False Floor
15% Tint All Around
Custom Painted Stock Rims
My Build Log
Tailights
15" Lvl 5 DC T-Line Build
  • Who's Online   0 Members, 0 Anonymous, 1376 Guests (See full list)
