Unfortunately the best way to learn is hands on practice. If you think your soldering skills are what made it fail, practice up on your soldering. Do you have any old circuit boards lying around? Just starting pulling stuff and soldering it back in. Get a bunch of small wire, cut it into small lengths and practice soldering them together. Stuff like that. Then apply that to your next recone.
97 Maxima SE
Bunch of shit going in, check out the build
Coil rub... did you shim it properly?
Make sure you let the glue set before you take the shim out... just be damn sure to pull it out before you put the dustcap on :P
10.x volts fo' life!
I used business cards, so they might not have all been the same thickness. Anyway, it was built to die.
SMD Super Seller
My Feedback Thread
man hearing things like this make me nervous, i just re conned my lvl4's with lvl5 coils. first time re conning for me as well, have not had chance to fire them up yet still working on my box.got my fingers crossed.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
NoFearX18 said:
trainman0978 said:
so you like that amp??? sounds like it
if there was coil rub need better shims also instead of of clips on the spiders i set the dust cap on WITHOUT glue and put about 7 pounds of weight on it that smashes the spider down for a good glue contact
glad to see it going to good use
deffinatly forgot to pull my shims out today while me and a buddy were reconing my subs... thankfully glue wasn't fully cured and we were able to get them out!! haha
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 2296 Guests (See full list)
