Running a second battery
Tried doing a search, but nothing came up. Could anyone give me a general idea on how you hook up another battery in the trunk? I'm not too sure on how to go about doing this. I know i have a pos duralast in the front, but I'm getting a Kenetik hc2000 tomorrow and would like to know how to hook that sucker up correctly. I've heard about isolators, but I don't know if ones necessary or not. Also if anyone has a diagram or some sort of picture, that would help a ton.
From reading things on google, I know I want to ditch the wetcell duralast and get a yellowtop for the front, correct? Then run a power wire from the pos (+) of the yellow, to the pos (+) of the Hc2000. Then simply ground the HC2000 in the trunk to the chassis, and fuse the power wire (0 gauge) from both ends within 18" of both batteries (or just 1 fuse?) with a 200A fuse. I will install this along with an 180A alt from Iraggi.
2006 Nissan Z Track.
My Feedback Thread
Really? No one knows :o
My Feedback Thread
Yes, positive of front batt to pos of rear batt. You could ground the rear batt to the frame or runa ground from the front batt to the rear one, you'll find arguments for both. Fuse both ends of the positive wire.
SMD Super Seller
My Feedback Thread
What you wrote is mostly correct. Yellow tops are good starting batteries, but they are nearly useless for car audio (using them solely for storage) unless you have a group 31 yellow top. You will be fine using it in conjunction with the Kinetik. I suggest making plans to replace it with a Kinetik (or Powermaster) down the road since you are using a decent size amp.
Fusing is always a good idea on both sides since you could potentially short in the middle some day. I recommend also running a negative throughout so you have a consistent and guaranteed path of flow. If that's not an option, grounding to the frame will be sufficient.
Need an install? Hit me up.
[email protected]
- post battery to rear - post battery
+ post battery / fuse beside it to rear + post battery with fuse beside it
or you can ground the rear battery post to the chassis if you don't want to run it to the front. I did add another fuse to the amp at the rear + battery post. There alots of thread on running second battery.. Just search..
So can I just keep my duralast in the front? + from that to + of kenetik, and ground the kinetik in the trunk?
My Feedback Thread
yes that will work. i believe running another neg. from front to back will be a little more efficient but not by much as long as you have a strong ground in the back. but like they said you're gunna want to replace the bat. up front eventually but its not necasary right now.
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
Cool. That'll save me a lot of money and hassle. So here's my diagram, tell me if it's correct.
My Feedback Thread
looks good, good luck
New Project
[top secret]
Yes and also fuse between the batt and the amp as well...
HU...Pioneer 5900IB
Wireing...Stinger
Amps...(1) Modded Stetsom 2K6..
Batts...(1) Stinger 2150
SPL Subs...(2) DD 9515 Hybrids
Daily Subs..(1) Mmats P3.0 15
N.S.P.L.
2012 NC State Record Trunk 1801-3600
2012 World Record Trunk 1801-3600
2011 NC State Record No Wall 0-24"
2011 NC State Record No Wall 0-24" Hardcore
2011 World Record No Wall 0-24"
2011 World Record No Wall 0-24" Hardcore
2010 World Record No Wall 0-2500w
2010 NC State Record No Wall 0-2500w
2009 NC State Record No Wall 0-24"
2009 NC State Record No Wall Hardcore 0-24"
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
