run soft copper pipe, hook up 12 volt water pump, use transmission cooler under vehicle, install aquastat, and you can cool whatever you want. an aquastat wired into the pump will tell the pump when to turn on and off at preset temps. the transmission cooler acts as a heat exchanger. you can even put a windshield washer reservoir or something similar in the loop to gain more capacity of liquid.
I just figure condensation would become an issue if your running refrigerants or something. What if you tried to.cool the enclosure itself ie:. TEC's or something
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
No one caught my last comment huh?
Its been tested and proved and is the best method to super cool woofers.
Other methods wont do much, they have been tested.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
naw i didnt catch it. thats alot less work than what i did. i never did subs before, i only did it to the amps.
NOS is only -88.6c, should give Liquid Nitrogen a go. :P
Hammerdown... 1%
That wouldnt create a useful cooling effect.
You would have to pump cooled water directly into the pole piece and top plate.
You could machine out channels in the motor and tap a fitting into it that connects to a hose to carry water. Pretty much like bazooka did, then use a liquid cooling system from a computer.
Or
Just spray it with NOS.
NOS Ftw. :rofl:
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
some suvs have rear air conditioning.. just port that into your box with a check valve.. or right into the port.. to cool the subs.. i've seen it done.. but why would your subs be that hot anyways? get better subs.. or quit clipping shit is the best way to cool a sub imo..
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
  • Who's Online   0 Members, 0 Anonymous, 1592 Guests (See full list)
