mr.p Posted May 23, 2010 Report Posted May 23, 2010 do it and let us know what you observe. DCAUDIO BALLS DEEP
chud Posted May 23, 2010 Report Posted May 23, 2010 And I'd really like to know how adding a fuse holder to a ground "cleans up" an install. Get real. You can't fix stupid
finkster Posted May 24, 2010 Report Posted May 24, 2010 Well since nobody but andy answered why i will give you a short answer on top of his. measure the voltage at the input of the amp. around 14 volts. measure the voltage at the ground terminal of the amp. 0 volts. Anywhere up to a coil will be positive, anything after that will be either less or 0 depending on the circumstances (number of coils, and how its wired...yadda yadda)... no, it doesnt need to be fused. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
LilTeddyP Posted May 24, 2010 Author Report Posted May 24, 2010 I guess let me rephrase, CAN it be fused, I know it doesn't NEED it. I don't want to do something that is gonna fuck it up. I'll get copper tubing cut to fit in the fuse spot and make it a distribution block. 2001 Bravada (2wd) Pewter on 24's JVC KW-AV60BT 10 Alpine Type-S 6.5s 2 PSI/BTL 18's @ 32Hz 2 Rockford Fosgate T25001-bd's @ 1-ohm each Rockford Fosgate T1000-4 Rockford Fosgate T400-4 Rockford 3Sixty.2 Yellow top up front, 2 9a31s in the back LOTS of AT 1/0 Python 991 350 Amp Singer Alt "Build Log" My Facebook My YouTube i didnt see the video or read anything but...cool story and the reason your being a cock tonight is?
finkster Posted May 24, 2010 Report Posted May 24, 2010 sure. garbage in, garbage out. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
finkster Posted May 24, 2010 Report Posted May 24, 2010 ugh im buzzed sorry. let me rephrase. there is the same amount of potential on each side. difference is that we normally dont fuse grounds because if it touches bare metal in the car it doesnt matter, unlike a positive wire. you can fuse it for looks if u want, the fuse will conduct electricity just like the wire would. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
LilTeddyP Posted May 24, 2010 Author Report Posted May 24, 2010 What are the chances of that ground fuse popping, and not my pos fuse, making my amp want to see ground through my rcsa and fucking my pioneer deck up because they are notorious for that 2001 Bravada (2wd) Pewter on 24's JVC KW-AV60BT 10 Alpine Type-S 6.5s 2 PSI/BTL 18's @ 32Hz 2 Rockford Fosgate T25001-bd's @ 1-ohm each Rockford Fosgate T1000-4 Rockford Fosgate T400-4 Rockford 3Sixty.2 Yellow top up front, 2 9a31s in the back LOTS of AT 1/0 Python 991 350 Amp Singer Alt "Build Log" My Facebook My YouTube i didnt see the video or read anything but...cool story and the reason your being a cock tonight is?
CNF Kevosinn Posted May 24, 2010 Report Posted May 24, 2010 fuck horse's *** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ ) "kevosinn's" astro van 8 custom Sundown Zv4 18's 4 Sundown scv 6000's CNF Distribution CNC parts Skyhigh wire some batteries SMD Meters and tools used on the installhttp://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/ 16,000 watt walled silverado build.http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/ 8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60TEAM CNF Distribution
finkster Posted May 24, 2010 Report Posted May 24, 2010 sigh...dont worry about it.. Either everyone would fuse their grounds or no one would run pioneer if this was the case. well none of these is the case. Im going to bed. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
skittlesRgood Posted May 24, 2010 Report Posted May 24, 2010 the only thing i see it hurting is your current flow. you are adding an unnecessary bottleneck. if its just the looks of matching fuse holders and not wanting a distro block to throw of the looks, put a copper bar where the fuse should go. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
