Ok currently i am running 1 aq2200(since my other one burned out) on 2 Fi btl's. I recently bought a amp for my vocals and noticed when i connect the rca's to the vocal amp their is huge ground noise coming from the subwoofer...and when i unplug the rca's from the vocal amp their is no ground noise from the subwoofer. Note the subwoofer is amped to the aq2200 incase u didnt figure that out :) They are both grounded to the seatbelt bolt if that makes a differnce. The rca's are also ran in differnt sides from the 0gauge battery
could it be the vocal amp? its a cheap one i bought just temp its a pyramid lol
2 12' Fi Bl's
2 AQ2200
1 180 Amp Alternator(yea i know i need more amperage)
3 Optimas
0g wiring/big three
you have a shitty ground.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
or it could be that ten dollar amp for your highs.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Well it can be the ten dollar amp i bought...but the ground is solid under the seatbelt...not sure what it can be :/
2 12' Fi Bl's
2 AQ2200
3 Optimas
0g wiring/big three
I don't trust seat belt bolt.. I heard many issuse about it.. I like to make my own ground..
yeah don't use seat belt bolt at all.. DO bolt it down /w a couple washers, a bolt and a nut (cost me like 1 dollar at home depot dude). make sure you don't drill into the gas tank. also, use some sand paper so the ground is free of any paint. be thorough.
make sure you have good quality connections /w your power and ground wires too.. you know in case a terminal fork is loose (if you use that). make sure the fuse holder is nice and tight
cheap amps do cause weird problems. see about trading it out with a friend's amp just to test it.
have you tried different set of RCAs? i had the same issue and it was the RCAs , and they were brand new...
2002 civic
2- 12in dc lvl5s
1- crescendo 3kwp ( 1 more on the way)
1- stock honda alt
4-xs d3100s
3-asa300.2 amps
6- PB 4XL's
4-PB l-3h tweets
and a bunch of other sh!t
the build
http://www.stevemeadedesigns.com/board/topic/74044-project-will-it-fit/
Youtube channel
http://www.youtube.com/user/slammedblackbish
