What size T-Nut to mount Sa-12?
i was talking with someone about mounting my sa-12's with T-nuts... but i cant remember what size i should get... what size Tnuts should i use with my sa-12's?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
any input from anyone? id like to order them asap!!!
3 Kinetik Hc2000's
Dual 200amp alts.
1/4"x?" depending on the baffle thickness I usually use one 1/2" longer than I need.
Edited by wL<3bass
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
baffle is 1.5" thick... and i want to use bolts for a couple reasons... first, screws strip out too easy... and second, if some jackass decides to try to steal my shit... then they are going to have a tough time getting my woofers with a screwdriver or cordless drill and phillips bit....... seriously who carries around a socket set? :pardon:
3 Kinetik Hc2000's
Dual 200amp alts.
How are you planning on mounting this? I have a hard time with my t-nuts grabbing mdf. Its too hard or something so half the time they don't bite in and its a nightmare to get the woofer out after. Or a thought I just had was to mount the tee nut and then run a bolt from the backside so that you lay the woofer over the studs then put a nut on the stud sticking out. Might look funny. But if you lock the bolt against the t nut like double nutting I think this would work. Hell I might try it next time my subs are out
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
I used 1/4" t-nuts. To help them stay in so they don't spin out when screwing the subs in, instead of hammering them in, I put some wood glue on the side that faces the wood, put a sub in place and used the 1/4 bolts to pull them in. That way they are also lined up perfectly.
97 Maxima SE
Bunch of shit going in, check out the build
Be careful using T-nuts. If they do not bite into the wood very well, Like when using mdf, They will strip and spin like a loose nut.
A 1/4 - 20 will do just fine to feed through most speaker mounting holes
Edited by kingsuv
I drill the hole put a bolt through it with a big washer on it, and pull the tnut into the wood by tightening the bolt. I have never had one fall out, and I have about 48 in my box right now.
I use 1/4" to hold my subs in, and 3/8" to bolt my ports in
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
  • Who's Online   0 Members, 0 Anonymous, 1036 Guests (See full list)
