STUCK WINDOW! Can you help?!
How about I offer some actual help...
Check the red and yellow wires coming out of the drivers window switch... When pushing the up button check the yellow wire for 12v and the red for ground. They will be thicker gauge wiring. This will tell you if the switch is working.
Do the other windows work and did you check all the fuses?
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
Dear OP,
sorry to thread jack, let us know how it turns out. :drinks:
LMFAO!! OMG, anyways guys, my mom will be home from work here in like 30 mins, so i am going to try and check that.
At first ALL the windows wouldnt go up, so i checked and replaced all the fuses and the drivers window wont go up.
Had this happen in my ants car, the switch gets dirty and messed up over time, I usually get hers to work when i pull the switch out, then it works for a few months and stops, so could be a bad switch
take baby steps, u cant do it all at once unless u have a roll of 100's big enough to choke a donkey
1998 Chevy Venture "Swagger Wagon"
Kenwood Excelon KDC-X994 Headunit
3 15" Alpine Type R's in seperate T-Lines
1 RF T1500-1bd for 2 of the 15s
1 RF P1000-1bd for the single 15
3 sets of Hifonics Zeus ZXi6.5C Components( 1 more set to come for Front stage)
1 Hifonics HFi100.4 4-channel amp
Stock alt for now (DC HO SPL 400A when funds come in,currently working on buying this)
Stock battery and one Optima Redtop for now (looking at XS batteries)
3 15" Alpine Type R's (aka Swagger Wagon Build 1.0)
Swagger Wagon Build 2.0
Youtube Videos
you sure your pushing the right button? i did that once :werd_msword:
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
simple, the battery needs charged... either that or the driver door connection has a bad ground...
:rofl: what?
God damn its hot today. My balls are stuck to my leg.
To the OP. If you check out sableowners.com post it on the forums there and I guarantee you get exact answer with wire colors and everything. It does sound like a bad window switch though. It's common for a 20 year old switch to get bad contact on the metal prongs after so much use. Also, why were all of the fuses popped? Did you ground something out? Might have damaged more like the window motor or regulator. Sorry if anything is a report read through most of the replies but not all.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
vaca for someone here.
Thanks for stopping by FAG
And I vote bad switch
There are two wires going to the window motor.
They will be of heavy gauge. (thick)
Grab a cordless drill batt and touch the 2 wires to pos, and neg.
Try it both ways, 1 way is up, 1 is down.
If the window still doesnt go up, then it's the motor.
If it does go up, then its a bad switch or connection.
No not ALL the fuses were poped! Just the one for the windows and power locks
Hey man thanks! I never would have thought about the cordless drill batt. I will try that also! Im thinking it is the switch, also, cuz it was working fine and the motor wasnt slowing down. If that is the case looks like i am going to pull a part!
